RCmag :: Voir le sujet - pate rouge pour vilo
philippe27
MessagePosté le: 27.02.2009, 20:32:19    Sujet du message: pate rouge pour vilo Répondre en citant
bonsoir
a t on déjà évoqué un post pour cette pâte rouge pour vilo si oui merci de le supprimer
Update on the crankfiller silicone: The shipment arrived at the supplier and is on its way here, i will update once i get my hands on it.
Have you ever had the silicone filler come loose or even disintegrate out of the crankshaft of your favorite engine? Couldn't find the right stuff to fix it? What the hell is that stuff anyway and why is it such a big secret? Well, the factories told us if we have some that need fixing to send them to Italy or France respectively and they would repair the crankshaft. Yeah, good luck!
After extensive searching and trying different things i was able to find just the right stuff which is being used by prominent japanese engine builder. Now we will make this self leveling red rtv available to everybody that wants it, including any engine modder that would like to use it. As a note: It took about 3 months to locate and another 3 months to purchase this product. So don't waste your time and try to " get it yourself" unless you are prepared to buy large quantities after you locate the stuff.
Use what the Pro's use and get the RED RTV CRANKSHAFT FILLER right here from Reid R/C
sa ressemble a du CAF 1 silicones Rhodia ?????
Christophe
MessagePosté le: 27.02.2009, 20:51:12    Sujet du message: Répondre en citant
pour avoir déjà utiliser du CAF pour le montage de carter moteur je pense en effet que c'est exactement la même chose Wink.
leader47
MessagePosté le: 27.02.2009, 21:24:34    Sujet du message: Répondre en citant
C'est commercialiser ?
merci a ++
Petits bolides agenais
RC8.2 OS SPEKTUM JR
philippe27
MessagePosté le: 27.02.2009, 21:42:35    Sujet du message: Répondre en citant
voir ces liens
http://www.reidrc.com/news.htm
http://www.idn-idb.com/artweb/pdf/rhodiacaf1.pdf
http://www.bentleychemicals.co.uk/files/CAF_1_msds_1.pdf
Christophe
MessagePosté le: 28.02.2009, 13:04:57    Sujet du message: Répondre en citant
Salut, du CAF on en trouve normalement en magasins de moto.
philippe27
MessagePosté le: 28.02.2009, 20:34:14    Sujet du message: Répondre en citant
le 5399 unijoint loctite et le Reinzosil-t (dana)
pourraient t ils font la faire ????
