This kit is designed to be fun to drive and uses high quality parts with durability and performance. Best of all, we have included motors, speed control , hi-torque steering servo and painted body, so you just add your own radio gear and battery pack to start crawling. Endless fun included!
Specifications
Length: 425 mm
Width: 290 mm
Height:
Net Weight: 5 lbs exclude battery pack and receiver
Finish/Color: Silver anodized aluminum parts
Notes:
Availalbe: NOW
BUY DIRECT
Features:
* Machined front and rear axles/gear boxes
* Steel gears
* Machined front bumper
* Alloy steering knuckles and wheel hubs
* 1-piece 2.2" alloy bead lock wheels with outer rings
* High performance tires
* Aluminum threaded shocks
* 4-link suspension
* 14.6 Kg/6V High torque metal gear steering servo
* Two 540 motors
* GV speed control
* Painted body
Related Products:
#EL667 Electronic Speed Control
Specifications:
* Cell number NiCd/NiMH:6-8 (7.2V to 9.6V)
Cell number LiPo: 2 (7.4V); There is no integrated LiPo low voltage protection!
* BEC: 5V, 1A
* Steady current (forwards): 5 minutes/80A, 30 seconds/100A, 1 second/120A
* Motor limit: 18 turns
* Battery connection: Tamiya-compatible
* Receiver connection: JR
* Pulse frequency: 200Hz
* Functions: Proportional forwards, break, proportional reverse
* Weight: Approx. 72g incl. wire
* Dimensions (L x W x H) Approx. 42 x 46 x 27mm (with cooling element)
#SRGV9051 Servo
Specifications:
* HIGH TORQUE METAL GEAR SERVO
* Weight - 49g
* Dimensions - 40.5 x 20 x 42mm
* Torque At 4.8V - 13.0kg-cm
* Torque At 6.0V - 14.6kg-cm
* Speed At 4.8V - 0.17 sec
* Speed At 6.0V - 0.15 sec
Tech Notes
ITEMS REQUIRED FOR COMPLETION :
1. 2-channel radio
2. 7.2V battery pack and charger
INSTALLATION: Read the instruction manual (PDF)
What’s in the box:
* Chassis Bag:
1. Chassis
2. Links
3. Threaded shock absorbers
4. Speed control
* Front Axle Bag:
1. Front axle assembly
2. Hi-torque metal gear servo
3. 540 motor
4. Steering knuckles
5. Wheel hubs
6. Steering rods
7. Bumper
* Rear Axle Bag:
1. Rear axle assembly
2. 540 motor
3. Wheel hubs
* Painted body
* Tires & Wheels
* Body posts, clips, motor wires, screws, Allen wrenches and cross wrench
* TSAIS decal sheet
* Instruction manual
