philippe27 Champion du monde
![](modules/Forums/images/avatars/1685.gif)
Posté le: 18.01.2012, 18:32:38 Sujet du message: System rapide d'emboitement sur boule de Cde |
jamais vu sur les totos ???
adapté pour d'autres discipline Rc ???
applicable dans certaines applications !!!
Locking Sleeve Ball Joints
These ball joints are made of glass filled nylon and provide a full range of motion, permitting off-axis operation. Unique, spring loaded, glass reinforced sleeve holds plated steel ball firmly in place yet is easily released for changes and final adjustment. These are ideal for throttle connections and internal servo arms.
Double Ball Joints
Elevator Splitter. Two ball links with locking sleeves connected to a plated steel “dumbbell” allows motion from the servo arm to two parallel surfaces at the same time.
Aluminum Ball Connector W/ Locking Sleeve
HD Aluminum Ball Connector for throttle connections and internal servo arms. These ball joints are made of machined aluminum and provide a full range of motion, permitting off-axis operation. Unique spring loaded, steel sleeve holds plated steel ball firmly in place yet easily released for changes and final adjustment. They come in three sizes and three colors: 4-40 in blue, 2-56 in red, and 2mm in green.
Features:
• Machined Aluminum for precise control
• Hard Coat anodized for protection against corrosion and wear
• Permits full range of motion
• HD Steel Ball included
• Color Coded
S590 2-56 Threaded Ball Joint
S591 4-40 Threaded Ball Joint
S592 2mm Threaded Ball Joint
S593- NEW 3mm Threaded Ball Joint
http://www.sullivanproducts.com/ContSysAccMainFrame.htm
http://www.sullivanproducts.com/S560.pdf
![](http://pics.towerhobbies.com/image/s/sulq3260.jpg)
Posté le: 18.01.2012, 18:36:54 Sujet du message: |
J'ai vu ça sur les vionvions ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Papy boomer
amontintin Champion du monde
Posté le: 18.01.2012, 18:41:19 Sujet du message: |
cela résisterai bien aux vibrations en TT 1/8°Th
et ou trouver le système
merci _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
mattcec Expert*
![](https://www.rcmag.com/images/avat_pot/matt.jpg)
Inscrit le: 12/12/2009 Messages: 492 Localisation: VIERZON Lig18
Posté le: 18.01.2012, 19:00:07 Sujet du message: |
salut,
j'ai commandé sur un site de vente aux enchères bien connu... |
Posté le: 18.01.2012, 19:02:18 Sujet du message: |
tu viens de commander?? ou tu as déjà reçu et monté/testé ![Cool](modules/Forums/images/smiles/icon_cool.gif) _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
Posté le: 18.01.2012, 19:04:12 Sujet du message: |
c'est fiable dans le temps et c'est pas trop gros en diamètre et Lg ??? |
Pierre43 Expert**
![](https://imageshack.us/scaled/thumb/16/76053husabergmy2014fe25.jpg)
Posté le: 18.01.2012, 19:41:26 Sujet du message: |
Quel est le plus adapté en diamètre pour nous car au niveau des taille, c'est pas évident de s'y retrouver? _________________ Une petite balade en Husaberg, ça fait un bien fou!!! |
pat4x2 Elite
Posté le: 18.01.2012, 19:43:39 Sujet du message: |
systeme utilisé sur les camions saviem, et oui c est pas d aujourd hui. mais pour la rc j ai utilisé ce systeme depuis les années 89, c etait des tringleries de bateaux rc. |
Posté le: 18.01.2012, 20:10:11 Sujet du message: |
pour les boules de carbu, c'est quel modèle qu'il faut???? ![Question](modules/Forums/images/smiles/icon_question.gif) _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
mattcec Expert*
Posté le: 18.01.2012, 21:12:19 Sujet du message: |
commandé aujourd'hui, j'ai pris le 2mm (correspondant au diamètre de la tige) |
romuald31 Elite
![](modules/Forums/images/avatars/0001.gif)
Posté le: 19.01.2012, 07:40:42 Sujet du message: |
bien pour les avions mais, pour ls voitres, cela ne marchera pas car, il faut de la course pour le frein et là, c'est bloqué par le système!!!!
En avion, la position frein, c'est la position pour caler le moteur en fermant le carbu...
