RCmag :: Voir le sujet - Avez-vous déjà utilisé ce produit de nettoyage MucOff ?
philippe27
MessagePosté le: 29.03.2014, 20:39:22    Sujet du message: Avez-vous déjà utilisé ce produit de nettoyage MucOff ? Répondre en citant
avez vous déjà utilisé ce produit de nettoyage MucOff sur vos Rc
vue dans une boutique de modelisme
vos avis sur ce produit
Nano Tech Bike Cleaner
Our fully biodegradable, all-over bike cleaner.
Benefits
Safe on all parts and surfaces including carbon fibre
Will not harm seals, cables, brake pads or rotors
Effective road bike & mountain bike cleaner
Safe on anodised metal
Alkaline based and free from CFCs, solvents or acids
Nano Tech Formula cleans on a molecular level
100% Biodegradable
5 litre carton = £5.40 per litre!
25 litre tub = £3.96 per litre!
Description
Using our state-of-the-art Nano Tech formula, Muc-Off cuts through grime quicker than you can say “OMG!” regardless of the weather or riding conditions. This classic pink Bike Cleaner has incredible cleaning power because it contains revolutionary Nano Technology that breaks down dirt and grime on microscopic levels, while also caring for your bike’s delicate finish. Because we use the finest ingredients and surfactants, our Muc-Off formula is a closely guarded trade secret.
It’s the most effective cleaner out there, and it doesn’t even need any of those nasty, dangerous acids or chemicals. In fact, our perfectly pink cleaner is fully biodegradable, free from acids, CFC’s and solvents, and it’s alkaline based so you can clean away with a guilt-free conscience. It’s safe on all surfaces, and it’s even disc brake rotor and pad friendly. Muc-Off Nano Tech Bike Cleaner is ideal for road bikes, mountain bikes, fixed gear bikes and commuting bikes.
Directions for use:
Step 1 - Rinse bike thoroughly before applying Nano Tech Bike Cleaner.
Step 2 - Spray Nano Tech Bike Cleaner onto the entire bike including components and leave for 3-5 minutes.
Step 3 - Agitate any stubborn grime with a brush or sponge.
Step 4 - Rinse entire bike thoroughly with fresh, clean water.
http://muc-off.com/clean/10-bike-cleaner-5037835904000.html?ref_cat=8
http://vimeo.com/81402318#at=0
http://muc-off.com/watercraft/110-marine-cleaner.html
philippe27
MessagePosté le: 29.03.2014, 20:42:31    Sujet du message: Répondre en citant
https://www.facebook.com/photo.php?fbid=266233566857750&set=a.266233533524420.1073741827.131842023630239&type=3&theater
https://www.rcmag.com/modules.php?name=Forums&file=viewtopic&p=715994
philippe27
MessagePosté le: 29.03.2014, 20:44:03    Sujet du message: Répondre en citant
a 1ere vue produit bio !
maxou72
MessagePosté le: 29.03.2014, 20:49:59    Sujet du message: Répondre en citant
Je l'utilise depuis la saison dernière. Une produit tout simplement magique que je conseille. Wink
TEKNO RC EB-48.2 SCT Pro 120A-Tenshock 1850Kv
Durango DESC210R Beeman 8.5T Hobbywing SC8
MBX6 Rally Game
Losi 22 Mamba max Hobbywing 8.5T
Mini Bolide CLub de l'Ouest-MBCO
JUST FOR THE FUN Very Happy
vroum-x
MessagePosté le: 29.03.2014, 20:52:33    Sujet du message: Répondre en citant
c est sur ce produit est magique.
pascalg
MessagePosté le: 29.03.2014, 21:01:13    Sujet du message: Répondre en citant
+1, force est de reconnaitre que ce produit est efficace OK!
Mumuch
MessagePosté le: 29.03.2014, 21:05:26    Sujet du message: Répondre en citant
c'est de la bombe !!!! rien de mieux pour enlever la terre qui a séché sous le chassis Wink en plus ca ne fait pas rouiller OK!
Référent Seine Maritime
philippe27
MessagePosté le: 29.03.2014, 21:17:22    Sujet du message: Répondre en citant
comment vous utilisez ce produit
et sur les parties électrique ???
recommandé aussi pour les RC BS ???
maxou72
MessagePosté le: 29.03.2014, 21:21:47    Sujet du message: Répondre en citant
Pour l'électronique, un petit peu sur un chiffon ou du papier absorbant et tu frottes. C'est comme ça que je fais et aucun soucis Wink
MBX6 Rally Game
chewbacca-rs3
Présidents
MessagePosté le: 29.03.2014, 22:34:17    Sujet du message: Répondre en citant
+1. Top produit. On le trouve a 100 Roro les 25 l.
bunny
MessagePosté le: 29.03.2014, 22:44:17    Sujet du message: Répondre en citant
Produit au top même apres 4 mois sans avoir touche la voiture de mon fils qui était pleine de terre la voiture est comme neuve .
TecraceRC
MessagePosté le: 29.03.2014, 22:46:59    Sujet du message: Répondre en citant
Le meilleur produit que je n'ai jamais utilisé sur mes voitures, juste top.
JP
titis14
MessagePosté le: 29.03.2014, 23:41:24    Sujet du message: Répondre en citant
Intéressent 35€ les 5 litres sur un site de vente bien connu qui à les frais de port gratuit.
Séb-r
www.rcpirate.fr
Xray GTX8 + Reds GT5
Donka
MessagePosté le: 30.03.2014, 00:17:46    Sujet du message: Répondre en citant
Pour info,on peut le trouver en import à environ 3.50e le litre mais par 25l
Very Happy
bunny
MessagePosté le: 30.03.2014, 10:05:43    Sujet du message: Répondre en citant
Sur des sites de bike tu peux le trouver à 30 euros les 5 litres livré en point relais
aour
MessagePosté le: 30.03.2014, 11:48:00    Sujet du message: Répondre en citant
et l'alcool ménager supérieur 95° ça marche aussi et plus simple à trouver
Mdp177
MessagePosté le: 30.03.2014, 12:04:13    Sujet du message: Répondre en citant
Very Happy
Ça évite de se faire pigeonner quand tu achetes une fiole à 12€..
Perso je suis bien content du produit..
kistof
MessagePosté le: 30.03.2014, 12:04:21    Sujet du message: Répondre en citant
Oui mais alors c est tres mauvais sur les joints toriques/plastique d étanchéité ,les graisses (roulements) et des fois ça fait légèrement blanchir les plastiques
la lampe torche, le PQ aussi.
Gazzz
MessagePosté le: 30.03.2014, 12:11:07    Sujet du message: Répondre en citant
Utilisé sur VTT et autres "engins" boueux depuis plus de 15 ans ! OK!
