Posté le: 28.12.2016, 20:49:41 Sujet du message: Camion Benne Hyd 1/14 RC4WD 8×8 Armageddon Volvo FMX
Specifications:
Hard Plastic European Style Front Cab
Full Metal 2 Speed Transmission (Planetary Gears)
Transfer Case (Billet Aluminum)
Scale Fuel Tank (Billet Aluminum)
Super Scaled Leaf Spring Suspension Setup
Scale Rims (Billet Aluminum)
Remote Lockable Rear Axle (Locking Differential)
Full Metal Front and Rear Axle Housing
Steel Scale Drive Shaft
Realism Front Cab Latch
Retractable Steel Ladder
Molded Functional Fuel Tank (Filled with Hydraulic Oil)
Automatic Trailer Gate (Do Not Attempt to Open by Hand)
Rear Light Guard (Protects Against Rocks)
Scale Light Buckets (Fits 3-5mm LED)
Recommended Payload: 15kg / 33lbs
Maximum Lift Power: 42kg / 92lbs
Fully Painted
Scale Fire Extinguishers and Spare Wheel/Tire
Cylinder Maximum Thrust: 109kg / 231lbs
Brushed Driven Motor
1000KV Brushless Motor-Driven Micro Hydraulic Pump
Length: 690mm / 27.1 inch
Width: 186mm / 7.3 inch
Height: 262mm / 10.3 inch
Weight: 8.9kg / 19.6 lbs
Axle Gear Ratio: 2.6 : 1
Transfer Case Gear Ratio: 1 : 1
Theoretical Load: 15kg / 33 lbs
Load Total Mass: 24.5kg / 54 lbs
First Gear 1:16, Second Gear 1:4 (Transmission)
Basic 6 Channel 2.4Ghz Radio
30 Days Limited Warranty
This Product Is Professionally Pre-assembled
