Posté le: 18.06.2018, 17:24:25 Sujet du message: PR Racing SC201 RTR
Disponible chez
Specifications:
High Power Sensorless 3900KV Brushless Motor
Powerful Brushless Electronic Speed Controller
2 Channel 2.4Ghz Surface Radio System
High-Speed 6kg Servo
Unpainted Body
Full metric hardware
Sealed Metal Ball Bearings
12mm hex Wheels (front and rear)
Oil-Filled 13mm Big Bore Plastic Threaded Shocks
Steel CVD Driveshafts
Width: 296mm
Wheelbase: 329mm
Gear Ratio: 2.6:1
Oil Filled Gear Differential
Dual Pad Slipper Clutch
Items required to complete:
Polycarbonate Paint for Body
2S LiPo Battery & Compatible Lipo Charger
Transmitter Batteries (4 x AA) _________________ Team CrazyDoc / merci FPmodelisme
