RCmag :: Voir le sujet - Kyosho NSR 500 Motorcycle kit
RCmag Index du Forum » Motos RC, dragsters, Karting ....
philippe27
MessagePosté le: 20.04.2010, 14:03:53    Sujet du message: Kyosho NSR 500 Motorcycle kit Répondre en citant
http://www.kyoshoamerica.com/cars/index.php?part_num=3021&view=techspecs
hese 1/8th scale bikes are as real as it gets when you turn the bike, the rider leans off the bike and helps the bike to turn. Add to that the mono shock rear suspension, upside down sliding front forks, real chain drive and beautifully detiailed rider and cowling and you have one cool R/C motorcycle.
Just add your radio, speedo and battery and you are off to the races.
* Leaning Rider mechanism creates a true to life look when the bike turns
* Mono shock rear suspension smooths out the bump and looks scale
* Spacious frame allows for cooling to the speedo and motor
For the ultimate is scale appearance in R/C motorcycles, look no further than the Leaning Rider Series kits from Kyosho. These 1/8th scale bikes are as real as it gets when you turn the bike, the rider leans off the bike and helps the bike to turn. Add to that the mono shock rear suspension, upside down sliding front forks, real chain drive and beautifully detailed rider and cowling and you have one cool R/C motorcycle.
Specifications
Length: 270mm
Width: 98mm
Height 190mm
Gear ratio: 13.8:1
Tire size (F/R): 86mm x 23mm
Wheelbase: 185mm
Weight: 750g
Mono shock rear suspension smooth out the bump and looks scale
We also offer the special electronics for these motorcycles. Please ask
http://www.youtube.com/watch?v=eJErcWL2NPQ
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » Motos RC, dragsters, Karting .... Toutes les heures sont au format GMT + 1 Heure
