Posté le: 16.05.2010, 15:18:13 Sujet du message: RC4WD Killer Krawler RTR - Rock Crawler 1/6
Killer Krawler is one of the largest RC Crawler available! Now available in Ready To Run! Everything is billet high quality precision aluminum parts. This crawler has a massive 150mm/5.9inch center ground clearance and 406mm/16 inch wheel base. Killer bullet proof axle with wide gears has an extremely wide turning radius and can articulate 60 degrees!
* CNC Machined Killer chassis
* CNC Machined Killer axle
* Outcry dual motor ESC with BEC
* 15kg high torque metal servo (two)
* 2.4Ghz radio and receiver
* Heat treated stainless steel spool gear
* Max volume adjustable piggy back shocks
* Killer angled suspension arms
* Front and rear billet bumper
* Full metal steering kit
* Full ball bearings
* Gear ratio: 30:1
* Length: 546mm/21.5 inch, Width: 510mm/20.47inch, Height: 250mm/9.84inch, Axle ground clearance: 70mm/2.75inch, Middle ground clearance: 150mm/5.90inch
* Wheel base: 16" (406mm) wheels on-center
* Fully assembled
