RCmag :: Voir le sujet - Protection Thermique pour réservoir a carburant MBX8
philippe27
MessagePosté le: 09.03.2018, 17:02:25    Sujet du message: Protection Thermique pour réservoir a carburant MBX8 Répondre en citant
New VRP carbon fiber fuel tank guard and heat shield for MBX8
New from Vision Racing Products:
www.visionracingproducts.com
New from VRP is our Mugen MBX8 Carbon Fiber Fuel Tank Guard with added Heat Shield. The Carbon guard will keep the pipe from ever burning into your fuel tank, and the Heat Shield will keep your fuel tank from absorbing excess heat from your exhaust pipe. Easily bolts right onto the lower two screw holes on the side of the tank. The Heat Shield is precision cut .5mm smaller so it is easy to seal the edges with thin c/a, giving you a nitro proof set-up that will last.
Made in house at VRP in Houston, Tx
Cut from 1mm Carbon Fiber
Helps protect your fuel tank
Keeps your fuel tank from absorbing excess heat
100% Made in the USA
