denislamalice Elite
Posté le: 26.11.2009, 21:40:44 Sujet du message: La Serpent 966 Electrique. |
Brushless et LiPo !!
Accélérations fulgurantes garanties avec les 4 roues motrices et deux packs d'accus !
Serpent has developed the 1st purpose made 1/8 scale electric onroad car for onroad circuit use . Its fully based on the highly successful Serpent 966 platform and shares the main components. The center section is reserved for the electric components. It features a purpose designed nylon bracket / holder for all components, like the 2 saddle packs 4800 ore higher cap. Cells, the speedo and the receiver. The large high power BL motor is securely mounted on a sturdy aluminium motorplate between the rear 2-speed bracket and the alu radioplate support. All elements have been positioned in such a way that an optimal weight balance of the car is maintained. Silent high performance ….. incredible acceleration …..amazing top-speeds
Serpent will also offer a Conversion set, to change your 960 or 966 into a full blown electric racer .... so you may just want to hang on to your 2009 car for this purpose. 904000 Serpent 966-E 1/8 4wd EP 904100 966-E conversionset
Sortie prévue Mi-Décembre ! _________________ Denis Sallé |
denislamalice Elite
Posté le: 26.11.2009, 21:49:09 Sujet du message: |
Bah supprime tracto ! _________________ Denis Sallé |
denislamalice Elite
Posté le: 26.11.2009, 21:53:27 Sujet du message: |
Quoi que l'on puisse développer le sujet côté piste !! _________________ Denis Sallé |
Posté le: 26.11.2009, 21:56:15 Sujet du message: |
ce nouveau forum date d'aujourd'hui, ce sera ensuite visible dans les 2 donc évitons les doublons, faut juste etre patient _________________ rcmag.com pour le forum, les photos et vidéos
denislamalice Elite
Posté le: 27.11.2009, 14:05:02 Sujet du message: |
