RCmag :: Voir le sujet - probleme de couronne centrale JQ "the car"
RCmag Index du Forum » TT 1/8 JQ Products
Poster un nouveau sujet   Ce sujet est verrouillé, vous ne pouvez pas éditer les messages ou faire de réponses.
modelboys
MessagePosté le: 08.01.2011, 15:30:27    Sujet du message: probleme de couronne centrale JQ "the car" Répondre en citant
vu sur neobuggy:
Whilst its disappointing for any customer to find there is a problem with a kit, at times it seems inevitable with any young or old company that this may happen; in the case of THE Car, JQ has acknowledged a problem with the main gear and will be offering free replacements to customers.
We received reports that some maingears have been breaking, and as we had not broken a single gear during the development of THECar we knew something wasn't right. And as it turns out, we made a mistake. As you can see in the image below, the production gear on the left doesn't have enough material below the teeth. The pre-production gear on the right does. We are currently producing new gears which should be done by the end of the month.
So what now? Well if you have been running THECar without problems, you will probably not break the gear, as it seems to break immediately, or not at all. If you do break the gear, and do not want to try another one, you can run a Losi 45t gear, and use the JQ gasket, along with a Losi gasket, and it will work as a temporary fix.
When the new gears are done we will inform you how to get you free replacement.
en gros, il y a un probleme de couronne centrale qui serait susceptible de casser tres rapidement
JQ est en train d'en développer une autre plus résistante
en attendant, il est possible de monter une couronne losi, et des disponibilité, cette piece vous sera remplacée gratuitement
http://www.neobuggy.net/modules/news/article.php?storyid=9570
MessagePosté le: 08.01.2011, 16:02:38    Sujet du message: Répondre en citant
Déjà poster Wink
Poster un nouveau sujet   Ce sujet est verrouillé, vous ne pouvez pas éditer les messages ou faire de réponses.    Haut de page » Accueil » RCmag Index du Forum » TT 1/8 JQ Products Toutes les heures sont au format GMT + 1 Heure
