RCmag :: Voir le sujet - Chargeur Eachine-D800-7A-80W-Dual-Input-Power-ACDC-Balance-C
philippe27
MessagePosté le: 04.07.2016, 07:32:21    Sujet du message: Chargeur Eachine-D800-7A-80W-Dual-Input-Power-ACDC-Balance-C Répondre en citant
Eachine-D800-7A-80W-Dual-Input-Power-ACDC-Balance-Charger-for-NiCd-NiM
Specifications:
Brand Name: Eachine
Item Name: Dual Input Power AC/DC Balance Charger
Item NO: D800
Dual input power: (AC/DC)
Input AC: 100-240Volt
Input DC: 11-18Volt
Circuit power Charging: max.80W
Circuit power Discharging : max.15W
Charger current range: 0.1-7.0A
Discharger current range : 0.1-1.0A
Current drain for balancing Lipo : 300mAh/cell
NiCd/NiMH battery cell count: 1-15 cells
Lithium battery cell count: 1-6Series
Pb battery voltage: 2 to 20V
Weight: W/Cable=531g W/out/Cable=437g
D800 Dimension: 136 x 172 x 56mm
Package Size: 227 x 158 x 80mm
Included Contents:
1 x D800 charger
1 x Power cord
1 x DC output cable
1 x T plug output cable
1 x Manual
1 x T-plug to XT60 converter adapter (Gift)
Suggested Optional Accessories
LM35 Temperature Sensor - CLICK
Parallel Charging Board - CLICK or CLICK
D800 Features:
High-power and high-performance circuit
Individual voltage balancer for Lithium batteries
Balance individual cells while discharging
Compatible with multiple types of Lithium Batteries
Lithium battery - "Fast charge" and "Storage" mode
Maximum safety
Data store/load
Cyclic charging/discharging
PC based analysis using USB communication (Requires add-on USB adapter)
3pin temperature sensor interface, with temperature measurement function, at any time to monitor the battery temperature (Requires add-on Temperature sensor)
Heat dissipation: plastic cover built in cooling fan.
Display type: 16chr. x 2lines with a backlight LCD screen
