RCmag :: Voir le sujet - Pièces de D8 Modifiées ou news
philippe27
MessagePosté le: 25.06.2010, 13:24:17    Sujet du message: Pièces de D8 Modifiées ou news Répondre en citant
67218 DCJ Drive Shaft (1pc)
Replace DCJ drive shafts parts as needed with genuine HB parts.
#67217 DCJ CENTER DRIVE SHAFT COMPLETE SET (FRONT/1PC)
#67218 DCJ DRIVE SHAFT (1PC)
#67219 DCJ DRIVE SHAFT SLEEVE (1PC)
#67221 DCJ COUPLER (1PC)
#67404 UNIVERSAL JOINT REBUILD KIT
67219 DCJ Drive Shaft Sleeve (1pc)
autre
67221 DCJ Coupler (1pc)
67180 WCE CVD Coupler/Pin Set(4)
[img]http://www.hotbodiesonline.com/graphics/parts/67180
/67180_000.jpg[/img]
Repair parts for WCE Drive Shafts #67170, 67171, 67174, 67177, 67178, and 67179 It will not fit to #67407 drive shaft
67220 Clutch Springs (1.1mm/3pcs)
Tune your D8 and D8T clutch with the slightly stiffer than stock, silver clutch spring. The extra tension on the clutch springs allows the engine to rev higher before engaging the clutch.
#67165 HB D8 Lightweight Clear Body
