RCmag :: Voir le sujet - Servo Radiopost Std , Rapide, puissant 20.7 mm
philippe27
MessagePosté le: 22.12.2011, 14:28:12    Sujet du message: Servo Radiopost Std , Rapide, puissant 20.7 mm Répondre en citant
Servo Radiopost
Features
Multi Type Model No: RP2207M
Radiopost servos are the only servos in the market using robot actuator technology and 32-bit resolution allowing ultra quick response and precise movement. They have an aluminum heat sink to dissipate heat. Ultra efficient coreless motor with a titanium-hybrid gear system powers any application. RP2307M Multi-Type servo is ideal for any application.
* Model: RPS2207M (Multi Servo)
* Voltage: 4.8V ~ 8.4V
* Operating: PWM
* Torque:
o @ 6.0V: 249 oz in
o @ 7.4V: 305 oz in
* Speed:
o @ 6.0V: 0.08sec/60°
o @ 7.4V: 0.07sec/60°
* Dimensions: 41.4x20.7x37.8mm (Without wing bracket)
* Weight: 65g
Speed Type Model No: RP1005M
Radiopost servos are the only servos in the market using robot actuator technology and 32-bit resolution allowing ultra quick response and precise movement. They have an aluminum heat sink to dissipate heat. Ultra efficient coreless motor with a titanium-hybrid gear system powers any application. RP1005M Speed-Type servo is ideal for applications requiring blinding speeds.
* Model: 1005M (Speed Type Servo)
* Operating: PWM
* Torque:
o @ 4.8V: 111 oz in
o @ 6.0V: 138 oz in
o @ 7.4V: 165 oz in
* Speed:
o @ 4.8V: 0.06sec/60°
o @ 6.0V: 0.05sec/60°
o @ 7.4V: 0.04sec/60°
* Weight: 65g
Torque Type Model No: RP3009M
Radiopost servos are the only servos in the market using robot actuator technology and 32-bit resolution allowing ultra quick response and precise movement. They have an aluminum heat sink to dissipate heat. Ultra efficient coreless motor with a titanium-hybrid gear system powers any application. RP3009M Torque-Type servo is ideal for applications requiring heavy duty power. Specs: Voltage: 4.8V~8.4V; 419 in/oz, 0.09sec/60* at 7.4V; 333 in/oz, 0.10sec/60* at 6.0V; 41.4 x 20.7 x 37.8mm (without wing bracket)
Model: RP3009M (Torque-Type Servo)
Operating: PWM
* Torque:
o @ 6.0V: 333 oz in
o @ 7.4V: 419 oz in
* Speed:
o @ 6.0V: 0.10sec/60°
o @ 7.4V: 0.09sec/60°
* Weight: 65g
amontintin
MessagePosté le: 22.12.2011, 14:58:32    Sujet du message: Répondre en citant
les perfs semblent être là en tous cas....... voir le tarifs et la fiaiblité/endurance du truc Cool
philippe27
MessagePosté le: 22.12.2011, 15:00:24    Sujet du message: Répondre en citant
Tarif très élevé
servo haut gamme
MessagePosté le: 22.12.2011, 15:07:47    Sujet du message: Répondre en citant
Ben oui, mais ou Question , et quand Question , et chez qui Question
Papy boomer
Elle est pas belle la vie?
philippe27
MessagePosté le: 22.12.2011, 15:32:45    Sujet du message: Répondre en citant
au USA en direct ou
chez a.m.h.com
MessagePosté le: 22.12.2011, 15:37:34    Sujet du message: Répondre en citant
Moin cher qu'un KoPropo OK!
Je sais, aussi, remonter les liens images Smile
Le lien fabriquant, qui ne vend pas en ligne, mais qui informe de ses revendeurs Wink
http://radiopost.com/default.aspx
Papy boomer
philippe27
MessagePosté le: 22.12.2011, 18:34:24    Sujet du message: Répondre en citant
merci papymini d'avoir préciser cela
effectivement distribution par ces revendeurs
http://radiopost.com/dealers/dealers.aspx
