RÉFÉRENCE ARRMA
ARA109011
NOM DU VEHICULE
LIMITLESS
ECHELLE
1/7
VITESSE MAXIMALE POSSIBLE
100+Km/H / 160+km/h
TYPE D'ALIMENTATION
Brushless
ETAPE DE MONTAGE
ROLLER
PIÈCES DISPONIBLES
ARA109011
HORIZON HOBBY NO DE PIÈCE COMMERCIALE
ARA109011
OPTIONS DE CONFIGURATION DE MONTAGE
Mid Motor
TYPE DE TRANSMISSION
4WD
TYPE DE VÉHICULE
Speed Machine
SURFACE
All-road
LONGUEUR
730mm / 28.74"
EMPATTEMENT
406mm / 15.98"
HAUTEUR DE CAISSE
15mm / 0.59"
LARGEUR AVANT
308mm / 12.13"
LARGEUR ARRIERE
305mm / 12.01"
HAUTEUR
165mm / 6.5"
BLOCAGE DES DIFFERENTIELS
No
NOMBRE DE DIFFERENTIELS
2
POIDS (SANS BATTERIE)
3.9kg / 8lbs 10oz
DIMENSIONS MAX BATTERIE
180x55x70mm / 7.09x2.17x2.76"
NIVEAU DE GARANTIE
2 Year Limited
RÉFÉRENCE ARRMA
ARA109001
NOM DU VEHICULE
INFRACTION
ECHELLE
1/7
80+Km/H / 128+km/h
TYPE D'ALIMENTATION
Brushless
ETAPE DE MONTAGE
RTR
PIÈCES DISPONIBLES
ARA109001
ARA109001
Mid Motor
4WD
TYPE DE VÉHICULE
Resto-Mod Truck
SURFACE
All-road
LONGUEUR
695mm / 27.36"
EMPATTEMENT
406mm / 15.98"
HAUTEUR DE CAISSE
15mm / 0.59"
LARGEUR AVANT
308mm / 12.13"
LARGEUR ARRIERE
305mm / 12.01"
HAUTEUR
200mm / 7.87"
No
3
4.8kg / 10lbs 9oz
NIVEAU DE GARANTIE
2 Year Limited
ARA109011
LIMITLESS ALL-ROAD SPEED BASH
ECHELLE
1/7
100+Km/H / 160+km/h
TYPE D'ALIMENTATION
Brushless
ETAPE DE MONTAGE
ROLLER
Mid Motor
4 roues motrices
TYPE DE VÉHICULE
Speed Machine
SURFACE
All-road
LONGUEUR
730mm / 28.74"
EMPATTEMENT
406mm / 15.98"
HAUTEUR DE CAISSE
15mm / 0.59"
LARGEUR AVANT
308mm / 12.13"
LARGEUR ARRIERE
305mm / 12.01"
HAUTEUR
.165mm / 6.5"
No
2
3.9kg / 8lbs 10oz
NIVEAU DE GARANTIE
2 Year Limited
