Posté le: 17.07.2007, 20:01:36 Sujet du message: Kit de conversion XB8 TQ => XB8 EC !
XRAY propose désormais un kit de conversion XB8 TQ => XB8 EC
#351101 Alu Chassis - CNC-machined 7075 T6 (3mm) - V2
#352089 Composite Front Brace - V2
#352091 Alu Front Shock Tower - CNC-machined Swiss 7075 T6 (4mm) - V2
#352113 Front XB8EC Lower Suspension Arm Right
#352123 Front XB8EC Lower Suspension Arm Left
#352250 Steering Block Right - V2
#352260 Steering Block Left - V2
#352651 Ball Stud 5.8mm with Backstop - V2 (2)
#353089 Composite Rear Brace - V2
#355601 XB8EC Univ. Centr. Drive Shaft - Set - Hudy Spring Steel™
#356116 Alu Radio Plate 7075 T6 (3mm) - V2
#358013 Composite Frame Shock Parts - Wide
#358036 Shock Piston Set - Wide (2)
#358051 Alu Shock Cap Nut - Wide (2)
#358060 Rubber Short Shock Boot (4)
#358061 Felt Shim for Rubber Short Shock Boot (4)
#358081 Shock Rubber Membrane - Wide (4)
#358121 Alu Front Shock Body - Hardcoated - Wide (2)
#358161 Front Shock Shaft - Long (2)
#358221 Alu Rear Shock Body - Hardcoated - Wide (2)
#359235 XRAY Premium Silicone Oil 350 CsT
#309319 Universal Set of Plastic Shims (only 2x shim 3×5x2)
#352500 Servo Saver Complete Set - V2 (Only Spring)
#354011 Center Diff Mounting Plate Set - Higher (only 2x lower plate)
#359307 XRAY Premium Silicone Oil 7000 CsT (only 10ml) _________________ Papy boomer
Elle est pas belle la vie?
