philippe27 Champion du monde
![](modules/Forums/images/avatars/1685.gif)
Posté le: 03.04.2009, 09:51:58 Sujet du message: Buggy Truggy Yada de chez Protech |
YADA ST RTR
* Extreme low Differential Center of Gravity.
* Extremely light Differential system
* Increased suspension travel to 7cm
* Pro steering geometry angle
* Moulded wing and Body included
* Lower CG design troughout the car
* Two Piece Pro center differential mount
* Full ball Bearing throughout the car
* Protech SX-21 engine included
* Complete 2 Channel radio included
* Laydown servo steering
* CNC Spur, Crown and Pinion gear
* 6061 Anodized Black Aluminium Radio Plate
* 6061 Anodized 3.2mm Alu main chassis
* 6061 Anodized Black steering plate
* 6061 Engine mount set
* 6061 Black center differential support plate
* Pro Turnbuckles
* 3 Shoe clutch
* Low profile radio box
* Pro brake pad
* Shock shaft of 3.5mm
* Rear swaybar
http://www.protech.be/html/yadast.html
manuel
http://www.protech.be/Manuals/T30manual%20web.pdf
Ils ont aussi la version Pro YADA PRO
* Increased suspension travel up to 7cm
* Moulded wing and transparent body included
* Carbon Radio Plate
* Carbon steering plate
* Carbon center differential support plate
* 7075 CNC lightened Anodized 3.2mm Alu main chassis
* 7075 CNC Engine mount set with black/chrome finish
* 7075 CNC lightened Rear & Front shocktower black/chrome finish
* 7075 CNC lightened Torque rod rear & front black/chrome finish
* Pro Turnbuckles
* 3 Shoe clutch
* Pro brake pad
* Rear & Front swaybar
* 1.7mm Rear & Front blue springs
* Universal CVD joints Rear & Front
http://www.protech.be/html/yadapro-x.html
et la version Truggy YADA TRR
* 100% Pre-built
* PROTECH SX-26 pull start engine
* 2-channel steering wheel radioset
* Painted & trimmed body
* 22 sealed ball bearings
* Ball type front suspension
* Countersunk aluminium T6 chassis
* Aluminium T6 radio plate
* Aluminium T6 shock stays
* CVD universal joints front
* 3 differentials with steel planetary gear
* Steel spiral bevel gears & pinions
* Steel main gear
* Double disc brake
* 3-shoe racing clutch
* 4 hydraulic constant volume shock absorbers
* Dust proof receiver box
* Adjustable wing mount
* Racing tuned pipe & manifold
* High grip off-road tyres
http://www.protech.be/html/yadatruggy.html
manuel
http://www.protech.be/Manuals/T33manual%20web.pdf
Posté le: 05.04.2009, 19:53:41 Sujet du message: |
pas beaucoup de commentaires pour ces produits |
Belgium1973 Expert**
![](https://i31.photobucket.com/albums/c387/Belgium1973/lexanfront34avatarSScorcher.jpg)
Posté le: 06.04.2009, 12:10:52 Sujet du message: |
pourtant c'est pas nouveau.... _________________ team BHM = Bien Haut Ma poule (dans les tours ou dans l'espace)
OCM driver |
Posté le: 06.04.2009, 17:28:05 Sujet du message: |
c'est une version du Caster ZX-1
le Ishima en est l'évolution
maxxou94 Découverte
![](https://maximec.olympe-network.com/maxxou94.png)
Posté le: 06.04.2009, 19:44:17 Sujet du message: |
salut
alors chris en a rentré ( des pro ) sur sa boutique et après analyse il semblerait que ce soit une pâle copie du mbx5 et a fait remarque que quasiment toutes les pièces étaient compatible
donc si c'est un mbx5 a mon avis y aura pas trop de soucis ![Razz](modules/Forums/images/smiles/icon_razz.gif) |
sournoizix Découverte
Posté le: 06.04.2009, 20:06:32 Sujet du message: |
Marrant, il y a aussi pas mal de pièces communes avec le STR8. (direction, cellules , et la carrosserie apparement!! ) ![Surprised](modules/Forums/images/smiles/icon_surprised.gif) |
Posté le: 06.04.2009, 20:18:03 Sujet du message: |
ses voiture n'ont pas été conçus par Protech ils sont juste defin un meccano avec des pièces de différentes provenance ??? |
Posté le: 06.04.2009, 21:53:25 Sujet du message: |
xxxx
edit papymini |
keven Expert**
![](https://a.imageshack.us/img25/9731/logothsirtavatar.jpg)
Inscrit le: 02/01/2008 Messages: 552 Localisation: Ligue 3 (MACA)
Posté le: 06.04.2009, 22:09:19 Sujet du message: |
heuuuu avast me donne 2 alertes virus sur le lien ci-dessus.... |
Posté le: 06.04.2009, 22:11:28 Sujet du message: |
je confirme le lien est vérolé virus très grave merci de supprimer ton lien
cheval de troie |
tmich Découverte
![](https://www.hpibajafrance.com/users/41/77/22/avatars/751-20.gif)
Inscrit le: 16/02/2005 Messages: 25 Localisation: Belgique
Posté le: 06.04.2009, 22:13:03 Sujet du message: |
keven a écrit: | heuuuu avast me donne 2 alertes virus sur le lien ci-dessus.... |
moi aussi |
noda Expert*
![](modules/Forums/images/avatars/gallery/_t2m08.jpg)
Posté le: 06.04.2009, 22:16:07 Sujet du message: |
En fait, c'est un STR8 avec train avant sur rotule. ![Cool](modules/Forums/images/smiles/icon_cool.gif) |
Posté le: 06.04.2009, 22:36:25 Sujet du message: |
ils avaient déjà un train avant sur rotules sur le Phaser 4 |
rafff Découverte
Posté le: 07.04.2009, 07:59:04 Sujet du message: |
le yada est un caster racing , identique aux STR8 mais ce dernier à un train avant sur fusée / porte fusée.
Simplement le Yada est sur le marché depuis maintenant 4ans. Le STR8 pas autant . |
Posté le: 07.04.2009, 08:13:56 Sujet du message: |
effectivement leurs conception est assez proche de l'un de l'autre avec une inspiration MBX5
ce qui est étonnant c'est que cette marque est peut representée en France considéré peut être a tore comme du loisir |
rafff Découverte
Posté le: 07.04.2009, 15:27:53 Sujet du message: |
si elle est considérer comme loisir , alors les hobbytech STR8 sont pareil ?? .... ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
Phred Elite
![](https://live.staticflickr.com/65535/50821171873_50c7b6475e_k.jpg)
Posté le: 07.04.2009, 15:34:56 Sujet du message: |
si y'a pas une solide équipe locale pour le promouvoir, il va effectivement rester aux oubliettes... du moins sur ce continent ! _________________ 3D imprimables : https://cults3d.com/en/users/PhredTech |
fwikiller Ligue
Inscrit le: 02/05/2004 Messages: 178 Localisation: Guadeloupe
Posté le: 07.04.2009, 17:18:25 Sujet du message: |
rafff a écrit: | si elle est considérer comme loisir , alors les hobbytech STR8 sont pareil ?? .... ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
La marque protech est considéré comme une marque de loisir car dans le passé leurs modèles était plutôt loisir.
Dire aujourd'hui que c'est toujours le cas alors que la marque n'est plus dispo en france serait une erreur.
Le yada est un chassis de compétition au meme titre que le str8 ou le rave. _________________ TEAM CLM RACING |
Christophe Elite
![](https://image.tmdb.org/t/p/original/68CyiTEIeVcZvwuVSKIsaFfQzVW.jpg)
Posté le: 07.04.2009, 18:07:10 Sujet du message: |
j'ai un Yada pro dans les mains et je trouve que la finition est très bonne, de plus toutes les platines sont en carbone et les pièces alu en alu 7075 qui semblent solides, je pense que c'est une voiture méconnue, pour le prix c'est une affaire.
La version pro est vendue largement pré montée :
On a à la base un seul fabricant (sous traitant) pour pas mal de marques : Protech, Ishima, Hobbytech, Caster et Piktor.
Voila pourquoi certains pièces sont compatibles quand elles ne sont pas identiques, après chaque fabricant a son cahier des charges et pour certains ils font fabriquer des pièces spécifiques.
J'utilise les amortos du Yada pro sur mon Kyosho et je trouve que ça marche plutôt bien. |
Posté le: 07.04.2009, 23:16:53 Sujet du message: |
bonsoir Christophe
sa serait intéressant de nous présenter ce châssis Yada pro (Protech)
tu as trouvé un vendeur en france ou tu l'as fait venir direct de chez Protech
a 1 vue tu apprécies les amortisseurs de ce châssis merci de nous préciser leur taille
As tu le montage avec soufflets sur les cardans ??
sympa ton site www.christopherc.fr.fm a voir
peut être l'avantage de tout cela c'est que l'on va avoir de plus en plus de pièces communes et courantes et facile a trouver dans le commerce (prix moins cher !!!) et moins de sortes de pièces a stoker pour les distributeurs
Gill0u2oo Expert**
![](https://img6.imageshack.us/img6/836/avatarzqs.jpg)
Posté le: 07.04.2009, 23:26:18 Sujet du message: |
Lorsque je me suis mit au 1/8 TT en course y'a environs 3-4 ans j'ai entendus parler du Yada .... au même titre que le Sportwerks Mayem.
Les produits Caster ne sont pas en retard .... loin de la !
Tant que ça roule et que les résultats sont bons ....
Le Yada n'as aucun pilote motivé .... faute de pub ...
Betch à tous ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Mes vidéos
X-Ray XB9 & sc10 losi.
pastis Expert*
![](modules/Forums/images/avatars/gallery/tigrou.gif)
Posté le: 08.04.2009, 00:12:40 Sujet du message: |
c'est quand meme loin du str8 et les pieces compatibles ne doivent pas etre nombreuses, et depuis il y a eu le V3
quand on voit les cellules c'est vraiment copier sur le mbx5 |
zef62 Expert**
Posté le: 08.04.2009, 09:19:49 Sujet du message: |
en ligue 4 il y a quelques yada qui roulent en promo et je peux vous dire que lorsque la voiture est bien préparée elle n'a rien a envié aux autres buggy
l'ishima reprend toute la transmission du yada ainsi que les platines les cellules et d'autres plastiques _________________ Mugen Mbx7R/Picco Boost/Sanwa/Spektrum |
fcjm78 Elite
![](https://img823.imageshack.us/img823/5585/wvua.png)
Posté le: 08.04.2009, 09:22:30 Sujet du message: |
le yada est une évolution de l'ishima avec amorto conventionnel? _________________ Ludovic Morlot 17050
30°north 1/5 short course
zenoah 29cc stock
spf froid et climatisation |
Posté le: 08.04.2009, 10:03:49 Sujet du message: |
a voir vos posts il y a quand même des TT Yada qui tournent en compétitions et vos commentaires sont assez l'élogieux d ailleurs
il faudrait voir pour présenter cet engin un peut plus en détail
vidéo
http://www.youtube.com/watch?v=VDeoBd2neIg
zef62 Expert**
Posté le: 08.04.2009, 14:38:14 Sujet du message: |
le yada est beaucoup plus ancien en conception que l'ishima qui est sorti il n'y a meme pas un an
en fait dans un soucis de réduction de cout l'ishima reprend quelques pieces du yada _________________ Mugen Mbx7R/Picco Boost/Sanwa/Spektrum |
cedric33 Découverte
Posté le: 16.04.2009, 18:38:52 Sujet du message: |
bonjour je suis a la recherche d'un boitier de differentiel d'une phaser 4 est ce que quelqu'un pourrai m'aider ![Shocked](modules/Forums/images/smiles/icon_eek.gif) |
Mikado62 Découverte
Posté le: 06.05.2009, 17:56:10 Sujet du message: |
Salut, je posséde une yada st qui roule vraiment bien, mais là je suis à la recherche de pièce et une carro. Mais Où les trouver ? Quels sont les marques compatible mbx5 et str8 ?
Cordialement |
Posté le: 06.05.2009, 20:27:50 Sujet du message: |
Mikado62 va voir ta messagerie |
