RCmag :: Voir le sujet - News amrtech Buggy GEARS 1/10 nitro RTR
RCmag Index du Forum » Loisir 1/10 nitro
philippe27
MessagePosté le: 12.11.2010, 18:03:40    Sujet du message: News amrtech Buggy GEARS 1/10 nitro RTR Répondre en citant
* Shaft-driven 4WD
* Smaller gear differential units
* Center limited slip clutch
* Adjustable front & rear down stop
* Adjustable rear toe angle & kick-up angle
* 8 degree approach angle
* 4 degree departure angle
* Long stroke suspension design
* 3 shoe type clutch
* Big bore shocks
* 58c.c. fuel tank / bubble filter inside
* Dirt-proof receiver & battery box
* Turnbuckle steering rod & suspension tie rod
* All Ball Bearing
* Wing mount adjustable angle
* Alum. Muffler & manifold included
* Front / rear universal swing shaft
* can use the starter box in the market to start GEARS 10
Specification
Wheel Base 240~243mm
Width 250mm
Tire & wheel type 1/10 EP Buggy type
Gear Ratio 11.02:1 ~ 13.46:1
Engine 10 CZ Engine pull start ( rear exhaust)
Weight 1500g (RTR)
http://www.amrtech.com.tw/products/pd_des.php?sid=1&sid2=54&pd_id=112
ils font peint de choses a voir
http://www.amrtech.com.tw/news/index.php
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » Loisir 1/10 nitro Toutes les heures sont au format GMT + 1 Heure
