RCmag :: Voir le sujet - Le nouveau Reedy 21ST
Le nouveau Reedy 21ST Aller à la page 1, 2  Suivante
quiks56
MessagePosté le: 31.03.2010, 21:06:00    Sujet du message: Le nouveau Reedy 21ST Répondre en citant
HBRACING.REEDS.SAVOX.6MIK..LA TEAM MORAT
RJdesign
MessagePosté le: 31.03.2010, 21:55:27    Sujet du message: Répondre en citant
superbe !! et que dire de l'insert mis a part "dommage qu'il ne se voit pas une fois monté "
Surprised
SANWA M8 2.4Ghz
MP9 / GRP tuned + 3009 / KANAI EVO3 STI + 2013 / ERG-VB / ERG-VRX
8IGHT-T / KANAI EVO3 STI + 2013 / SIRIO .28 MX STI + 2013 / ACE 1015 x2
bébéconfort trio + galia + pampers (lol)
quiks56
MessagePosté le: 31.03.2010, 22:10:23    Sujet du message: Répondre en citant
suffit de demander c'est encore des pré production je pense
quiks56
MessagePosté le: 31.03.2010, 22:11:13    Sujet du message: Répondre en citant
tiens une vis de plus sur le carbu
philippe27
MessagePosté le: 05.11.2010, 07:11:28    Sujet du message: Reedy 121VR-ST .21 Off-Road Competition Nitr 5 Novb 2010 Répondre en citant
Reedy 121VR-ST .21 Off-Road Competition Nitro Engine
November 5, 2010
The long-awaited Reedy 121VR-ST Competition Nitro Engine has finally arrived! Extensively track-tested by Reedy factory drivers such as Ryan Maifield, Craig Drescher, Neil Cragg, and Richard Saxton, the VR-ST incorporates state-of-the-art features in a proven package.
The current 121VR engine has proven to be an economically priced, powerful race engine. The 121VR-ST takes performance to an entirely new level with the addition of a balanced ADLC-coated crankshaft, ceramic rear bearing, lightweight piston, and ADLC coated wrist pin. An ultra-lightweight heatsink head with "diamond cut" fins improves cooling while lowering the center of gravity.
Available in December, the 121VR-ST is a race-proven engine that is capable of producing world-class power and fuel economy with a driver-friendly linear power band.
Features:
* 3+1 Port Chrome Plated Cylinder
* High Silicon CNC-Machined Lightweight Piston
* Knife-Edged 7075 Aluminum Connecting Rod
* ADLC-Coated Wrist Pin
* Chrome-Plated Back Plate with Turbo Scoop
* Balanced Turbo Scoop Crankshaft with ADLC Coating and Silicone Insert
* Precision Steel Front Ball Bearing
* Precision Ceramic Rear Ball Bearing
* Ultra-Lightweight Machined Aluminum Heatsink Head
* Oversized Finned Turbo Head Button
* Thermo-Insulated, Screw-Mounted 2-Needle Carburetor
* 7.0mm, 8.0mm, and 9.0mm Venturi Inserts
#801
121VR-ST .21 Buggy Engine
UPC: 784695008014
Available: Dec. 2010
http://www.teamassociated.com/news/latest_products/415-Reedy_121VR-ST_.21_Off-Road_Competition_Nitro_Engine/
molto88
MessagePosté le: 10.11.2010, 10:55:30    Sujet du message: Répondre en citant
sympa le news reedy!! vivement qu'il soit dispo, en esperant que son prix soit abordable comme pour la 1ere version.
S88R/ZENOAH/PMT
MP9/OS SPEED/PROLINE
http://www.vosloisirs88.com/modelisme/
TEAM FORAIN
rien ne sert de courir...non ca sert a rien!!!
bryce63
MessagePosté le: 02.01.2011, 00:26:51    Sujet du message: Répondre en citant
personne a de news ?
quiks56
MessagePosté le: 02.01.2011, 00:33:01    Sujet du message: Répondre en citant
il devrait pas tarder à être dispo en janvier normalement et pour le prix tu rajoute environ 70 euros du modèle de base
quiks56
MessagePosté le: 02.01.2011, 00:37:52    Sujet du message: Répondre en citant
la version de base est déjà tellement bien mais bon on en as jamais assez
quiks56
MessagePosté le: 11.01.2011, 12:24:50    Sujet du message: Répondre en citant
TEAM ASSOCIATED annonce qu'ils en ont en stock et qu'ils ont commencés à les expédier vers les mags donc bientôt dans les crèmeries
Fram
MessagePosté le: 11.01.2011, 12:50:30    Sujet du message: Répondre en citant
annoncé pour 320$ sur un célèbre site US...
quiks56
MessagePosté le: 11.01.2011, 12:58:48    Sujet du message: Répondre en citant
c'est moins cher et tout aussi bien que l'os speed xzb
philippe27
MessagePosté le: 11.01.2011, 22:47:41    Sujet du message: Répondre en citant
Bonsoir
SVP et merci d'avance pot vos réponses
est il possible de positionner le carbu dans l'autre sens ???
le tourner de 180 ° ???
quiks56
MessagePosté le: 11.01.2011, 22:51:16    Sujet du message: Répondre en citant
aucun soucis
Fram
MessagePosté le: 11.01.2011, 22:52:22    Sujet du message: Répondre en citant
D'apres ce que j'ai vu, le carbu est fixé par 2 vis verticalement dans le carter et le carbu possède 2 trous oblongs pour pouvoir régler l'angle avec la tringlerie de gaz. Si ces 2 vis de fixation sont symétriques, Il doit etre possible de retourner le carbu mais a confirmer...
quiks56
MessagePosté le: 11.01.2011, 22:57:05    Sujet du message: Répondre en citant
quiks56
MessagePosté le: 11.01.2011, 23:01:01    Sujet du message: Répondre en citant
superdupont
MessagePosté le: 12.01.2011, 14:57:09    Sujet du message: Répondre en citant
Y a pas de soucis tu peux tourner le carbu !!!!
A noter que Reedy a aussi modifié le carter depuis 5/6 mois !!!
En effet les transfert latéraux sont beaucoup plus gros de 2mm sur les dernières séries de moteur reedy Smile en prévision du st
Very Happy Very Happy
Actuellement je roule avec une buse de 5.5mm et ç'est tip top !!
www.ligue13.com
superdupont
MessagePosté le: 12.01.2011, 15:01:00    Sujet du message: Répondre en citant
Il ont aussi rajouté 1 mm de matière sous le carter au niveau du passage de la bielle Very Happy
www.ligue13.com
quiks56
MessagePosté le: 12.01.2011, 15:04:36    Sujet du message: Répondre en citant
ils ont l'air d'être identique
superdupont
MessagePosté le: 12.01.2011, 16:25:09    Sujet du message: Répondre en citant
J'ai eu les 2 carters entre les mains Very Happy Very Happy
Sur ta photo on peut voir l'ajout de 1mm de matière en bas du carter la ou il y a le passage de la bielle Very Happy Very Happy
Ensuite concernant les transferts regardebien dans celui du ST les transferts latéraux dépasse sur les pates de fixation moteur alors que l'ancien carter le transfert est à fleur Cool
www.ligue13.com
superdupont
MessagePosté le: 12.01.2011, 16:29:29    Sujet du message: Répondre en citant
Ancienne version
Nouvelle version
Mad Mad
www.ligue13.com
superdupont
MessagePosté le: 12.01.2011, 16:36:00    Sujet du message: Répondre en citant
Encore plus flagrant au niveau de l'écart entre les transferts Very Happy
Nouvelle version :
Ancienne version :
www.ligue13.com
quiks56
MessagePosté le: 12.01.2011, 19:54:06    Sujet du message: Répondre en citant
Bien vue j avait pas remarque cela dit aucun souci avec l ancien
ophjeje
MessagePosté le: 14.02.2011, 19:26:29    Sujet du message: Répondre en citant
Quelqu'un a-t-il eu l'occasion de tourner avec ce moteur ?
Y-a-t-il des retours, des impressions ?
Merci d'avance.
quiks56
MessagePosté le: 14.02.2011, 19:29:26    Sujet du message: Répondre en citant
je prend le miens le mois prochain
Fram
MessagePosté le: 14.02.2011, 19:41:48    Sujet du message: Répondre en citant
J'ai lu sur RCtech un petit pb sur ce moteur, mais je sais plus ce que c’était (pb sur le traitement de l'axe du piston qui ne resiste pas si je me rappelle ...)
A confirmer...
smagrad
MessagePosté le: 14.02.2011, 19:47:35    Sujet du message: Répondre en citant
bonsoir,
les roulement sont ils mieux que sur la premiere version?
car pour ma part 2 moteurs et les deux ont claqués le roulement ar vers 5 /6 litres... Shocked
BCM63
SWORKZ - DONUTS RACING - LABEMAX - SRT -
TPRO - PLP -
quiks56
MessagePosté le: 14.02.2011, 21:07:56    Sujet du message: Répondre en citant
roulement ceramique le mien a 15 l et aucun soucis
molto88
MessagePosté le: 15.02.2011, 19:29:01    Sujet du message: Répondre en citant
le miens a passé 35l et aucun pb de roulement
S88R/ZENOAH/PMT
TEAM FORAIN
