Posté le: 31.01.2011, 20:47:11 Sujet du message: Moteur Max power MX 21 Thunder MX 21
Moteur Max power MX 21 THUNDER MX 21 EXTREME
base Nova ???
Capacity 3,49 cc
Power 2,69 HP
R.P.M. 32,400 g/min.
Bore 16,26 mm
Stroke 16,80 mm
Ports 8 + BOOSTER
Sleeve ABC
Piston DIE CAST
Crankshaft Diameter 14 mm
Crankshaft with Tungsten NO
Silicone To The Inside YES
Crankshaft Type TURBO SG - DIAMOND COATING
Glow Plug TURBO
Carburetor SINGLE ADJUSTING
Weight 325 gr.
Capacity 3,49 cc
Power 2,65 HP
R.P.M. 32,300 g/min.
Bore 16,26 mm
Stroke 16,80 mm
Ports 5 + BOOSTER
Sleeve ABC
Piston DIE CAST
Glow Plug TURBO
Carburetor
Weight 325 gr.
MX 21 MAX RACER -
http://www.rcmaxpower.com/en/products/motori.asp?id=117
Capacity 3,49 cc
Power 2,60 HP
R.P.M. 31,500 g/min.
Bore 16,42 mm
Stroke 16,42 mm
Ports 3
Sleeve ABC
Piston DIE CAST
Silicone To The Inside NO
Glow Plug STANDARD
Weight 330 gr.
MX 21 MAX RACER D -
Capacity 3,49 cc
Power 2,61 HP
R.P.M. 31,600 g/min.
Bore 16,42 mm
Stroke 16,42 mm
Ports 3
Sleeve ABC
Piston DIE CAST
Glow Plug STANDARD
Weight 330 gr.
http://www.rcmaxpower.com/en/products/motori.asp?id=137
Capacity 3,49 cc
Power 2.63 HP
R.P.M. 31,900 g/min.
Bore 16,42 mm
Stroke 16,42 mm
Ports 5
Sleeve ABC
Piston DIE CAST
Glow Plug STANDARD
Weight 330 gr.
Capacity 3,49 cc
Power 2,63 HP
R.P.M. 31,800 g/min.
Bore 16,26 mm
Stroke 16,80 mm
Ports 3
Sleeve ABC
Piston DIE CAST
Glow Plug TURBO
Weight 325 gr.
Capacity 3,49 cc
Power 2,64 HP
R.P.M. 32,200 g/min.
Bore 16,26 mm
Stroke 16,80 mm
Ports 5
Sleeve ABC
Piston DIE CAST
Glow Plug TURBO
Weight 325 gr.
