RCmag :: Voir le sujet - New Piston d'amortisseur a clapets c2shocks
philippe27
MessagePosté le: 21.09.2011, 19:18:04    Sujet du message: New Piston d'amortisseur a clapets c2shocks Répondre en citant
source Buggy sport
New
[img]http://www.buggy-sport.info/index.php/gallery/image.raw?type=img&id=10210[/img][img]http://www.buggy-sport.info/index.php/gallery/image.raw?type=img&id=10211[/img]
Tasks of the new “Ride Control” shock absorbers pistons are the best possible control of wheel and spring movements.
Damping
Damping is the process of absorbing energy of impacts transmitted through the shocks on the compression and rebound stroke. A set of shocks are considered dampers. They slow the rate at which the suspension absorbs or releases energy. Damping is necessary to prevent uncontrolled spring oscillations in the suspension. The introduction of damping will absorb some or all of the energy imparted to the suspension by a bump. The oscillation will be reduced or eliminated, depending on the degree of damping. The up and down (kinetic) energy absorbed by the spring is restricted as oil flows through a valve in the damper body, resulting in hydraulic friction. This hydraulic friction creates heat, (thermal energy). This is why hard worked suspensions sometimes overheat. A damper is an energy absorber, matched to the rate of the spring, vehicle weight and style of driving. Imagine that a large bump has fully compressed a shock. At that instant, energy is stored in the spring as potential energy. As the spring rebounds to its static length it gives up this energy, which without damping, would be transferred entirely to the mass of the car in the form of kinetic energy (energy of motion). This would cause the spring, and suspension, to extend well beyond its normal position. This will have transferred the kinetic energy, in the opposite direction, back into stored energy in the spring, which will then repeat the whole process again. After any bump, we would proceed down the road as if on a pogo stick.
Damper speed
Damper Speed is the relative speed in which the moving end of a damper compresses (shortens) or rebounds (extends). Typically discussed as High Speed Damping (HSD) and Low Speed Damping (LSD). Low Speed Damping controls slow vertical movements of the suspension components such as those caused by rolling bumps, wavy pavement, acceleration or while making turns or braking. High Speed Damping controls fast vertical movements of suspension components caused by track characteristics such as square-edged bumps, rocks or jump landing.
The solution
The new C2 “Ride Control” shock absorber pistons gives you a better control of your car wheels movements. At low speed compression the oil flows just through the rebound holes in the piston. Due to the low pressure at low speed the shims open just a little.
At higher compression speed the shims open much more, it allows more oil flow through the compression holes in the piston.
In practical terms this means that the cars ride bumps in a much more stable fashion which in turn increases the efficiency of the car to give better braking, better exploitation of the tires and improved traction over bumps. The system can be modified varying the shim stack configuration and the viscosity of the shock absorber oil.
Ancienne version
AGAMA (2)
OFF ROAD-> (29)
STANDARD-> (29)
AGAMA (2)
ASSOCIATED (2)
BERGONZONI (2)
DURANGO (2)
EXPERTMODEL (1)
HOBAO (2)
HONG NOR / JAMMIN (2)
HOT BODIES (1)
KYOSHO (2)
LOSI (3)
LRP (1)
MUGEN SEIKI (3)
NANDA (2)
O'DONNELL (1)
SERPENT (1)
XRAY (2)
RIDE CONTROL
MISCELLANEOUS
autres
ON ROAD-> (4)
MOTONICA (1)
MUGEN SEIKI (1)
SERPENT (1)
SHEPHERD (1)
http://www.c2shocks.it/
Contractive suspension is a revolutionary concept which is claimed to be dramatically more efficient than traditional linear and variable rate suspensions.
These systems are, in effect, a compromise between the need to absorb vertical shocks and to avoid pitch and roll movement. The best compromise has traditionally been spring/damper units which are linked side-to-side by anti-roll bars.
Fram
MessagePosté le: 22.09.2011, 15:39:56    Sujet du message: Répondre en citant
et beh, apres tout le tintamarre fait lorsqu'on parle pistons a clapets, et quel top pilote machin les utilise et tout et tout... pas une seule remarque sur cette news apres 36h! Shocked
Vous etes tous en vacances? Laughing z'avez fini la saison? c'est la crise?
MessagePosté le: 22.09.2011, 15:49:15    Sujet du message: Répondre en citant
C'est tout en Anglais, peut-être que c'est illisible pour quelques membres, de plus, il manque des images Sad
Papy boomer
Elle est pas belle la vie.
Fram
MessagePosté le: 22.09.2011, 15:56:22    Sujet du message: Répondre en citant
ouais mais bon, pour une fois qu'il y a un truc techniquement interressant, tout le monde s'en tape.... Rolling Eyes faut faire un effort.
D’après la news, ils ont sorti un nouveau type de pistons a clapets, l'ancien modèle (celui en photo) ayant été amélioré sur le coté "progressif" de l'amortissement.
Perso ca me tente bien d'essayer les nouveaux quand ils seront dispo.
(En plus de ça, les tarifs ont l'air super corrects: 25 euros les 2 sets de 4 pistons pour avoir 2 diamètres de trous).
speedy2
MessagePosté le: 22.09.2011, 18:30:35    Sujet du message: Répondre en citant
voilà la photo manquante du nouveau système
on dirait 2 rondelles lexan et 1 en acier
Modérateur le 27.12.2011, 11:10:27; édité 1 fois
jb53
MessagePosté le: 23.09.2011, 07:29:18    Sujet du message: Répondre en citant
Pas de clapet en détente ? Empilage étonnant ,empilage standard ou on peut modifier? merci
amontintin
MessagePosté le: 23.09.2011, 08:50:13    Sujet du message: Répondre en citant
tel que c'est monté sur la photo, c'est en détente Cool
andremadracing
MessagePosté le: 23.09.2011, 09:03:39    Sujet du message: Répondre en citant
Je suis très heureux de voir que quelque chose ce fait à ce niveau.
Mad racing à choisi les billes, par facilité de réalisation, par fiabilité et par
soucis de reproduction, il y a beaucoup d'autres solutions!
Il n'y a pas que les clapets, en jouant sur le diamètre et le Nbre de trous
on plein de possibilités.
Bons essais
jb53
MessagePosté le: 23.09.2011, 09:28:08    Sujet du message: Répondre en citant
l'écrou est bien monter vers le haut (coté bouchon ?) si oui le clapet comme montrer ci dessus son en compression
Micland16
MessagePosté le: 23.09.2011, 09:56:39    Sujet du message: Répondre en citant
non non c'est bien en détente que c'est freiné.
Michaël LANDREVIE
philippe27
MessagePosté le: 23.09.2011, 10:18:20    Sujet du message: Re: New Piston d'amortisseur a clapets c2shocks Répondre en citant
[quote="philippe27"]Piston d'amortisseur a clapets c2shocks
New
Micland16
MessagePosté le: 23.09.2011, 11:14:57    Sujet du message: Répondre en citant
Une chose me chagrine quand même, c'est l'épaisseur totale qui doit quand même faire perdre du débattement, et le nombre de filets sur la tige est il suffisant pour être vissé correctement (la tige reste d'origine quand on regarde les kits sur leur site)
Michaël LANDREVIE
philippe27
MessagePosté le: 30.10.2011, 09:44:12    Sujet du message: Répondre en citant
Version Team edition c2shocks
The new "Team Edition" shock pistons have been optimized according to the indications supplied by many customers.
The project has been completely reviewed in the geometry and the materials.
With a simple kit you can transform the pistons in the "Ride Control" version.
The damping curves have been optimized for bumpy tracks and/or with many jumps.
http://www.c2shocks.it/pdf/news9.pdf
http://www.c2shocks.it/pdf/news7.pdf
tapenade
MessagePosté le: 30.10.2011, 10:18:17    Sujet du message: Répondre en citant
bjr
des distributeurs en france?
a+
Président du NSC de Mougins
nscmougins@gmail.com
http://nscmougins.com/
Facebook du NSC: nscmouginsautorc
philippe27
MessagePosté le: 30.10.2011, 10:25:31    Sujet du message: Répondre en citant
voir leur site
MessagePosté le: 30.10.2011, 11:48:45    Sujet du message: Répondre en citant
philippe27 a écrit:
Non pas pour l'instant
ils vendent en direct
voir leur site shop
ils ont un contact en Allemagne
Tu faits donc de la pub pour site marchand, non sponsor de RCmag Wink
C'est pas bien Smile
Charte de RcMag
Papy boomer
hp3
MessagePosté le: 30.10.2011, 12:15:01    Sujet du message: Répondre en citant
je ne vois pas l'intere de cette inovation sur la detente d'un amorto Question mais bon je dis ca... Rolling Eyes
JQ THE E CAR
DX3R 2.4 Ghz
servos ACE 1015,spektrum1040
MACN-Ligue17
amontintin
MessagePosté le: 30.10.2011, 12:24:28    Sujet du message: Répondre en citant
c'est justement tous l'intéret hp3. à l'échelle 1, les autos sont freinées en détente aussi Laughing
philippe27
MessagePosté le: 09.12.2011, 21:13:53    Sujet du message: Répondre en citant
http://www.c2shocks.it/pdf/mugen.pdf
http://www.c2shocks.it/pdf/associated.pdf
http://www.c2shocks.it/pdf/xray.pdf
autre
CONTRACTIVE SUSPENSIONS
La nouvelle suspension contractive C2 élimine le besoin des barres anti-roulis, car elle sépare les phases de contrôle de la compression et de l'extension du ressort, rendant plus indépendantes chaque roue. L'extension est contrôlée par l'utilisation d'un second ressort, qui est utilisé par opposition à le ressort principal. La compression utilise uniquement la dureté du ressort principal, tandis que l'extension utilise la somme des duretés des deux ressorts. En termes pratiques, cela signifie que la voiture roule sur les bosses d'une manière beaucoup plus stable, augmente l'efficacité dans les virages et en freinage. Le système assure également une meilleure utilisation des pneus et une meilleure traction sur terrain accidenté. S’abaisse aussi le centre de gravité lors de l'accélération latérale et longitudinale. INFO
Agentbull
MessagePosté le: 12.12.2011, 09:34:48    Sujet du message: Répondre en citant
j'ai vu plus haut la photo et si j'ai bien compris le ressort interne "ramolli" le ressort principal
donc plus mou pour des faibles débattements puis normal voir dure? Question
philippe27
MessagePosté le: 27.12.2011, 10:26:19    Sujet du message: Répondre en citant
KIT RIDE CONTROL Kit de maintenance et / ou transformation de TEAM EDITION à RIDE CONTROL. MUGEN - XRAY - ASSOCIATED - KYOSHO - HONG NOR
KIT RIDE CONTROL Kit de maintenance et / ou transformation de TEAM EDITION à RIDE CONTROL. LOSI
http://www.c2shocks.it/pdf/losi.pdf
MessagePosté le: 27.12.2011, 10:43:41    Sujet du message: Répondre en citant
philippe27 a écrit:
SERVICE KIT RIDE CONTROL Kit de maintenance et / ou transformation de TEAM EDITION à RIDE CONTROL. MUGEN - XRAY - ASSOCIATED - KYOSHO - HONG NOR
SERVICE KIT RIDE CONTROL Kit de maintenance et / ou transformation de TEAM EDITION à RIDE CONTROL. LOSI
Ajouter au panier Avis des clients
Si ce n'est pas un site commercial Question Mad
Papy boomer
Lopi
MessagePosté le: 27.12.2011, 18:56:20    Sujet du message: Répondre en citant
Est ce qu'il y a un modèle pour le S811?
seb6mik
Sponsors
MessagePosté le: 28.12.2011, 10:04:49    Sujet du message: Répondre en citant
Ces produits seront bientot distribués en France avec toutes les infos techniques nécessaire à une bonne utilisation… Wink
davy_ram
MessagePosté le: 28.12.2011, 16:27:56    Sujet du message: Répondre en citant
avez vousdéja utilisé ce type de piston?
cela apporte t'il un plus?
merci d'avance pour ta réponse seb
mattcec
MessagePosté le: 28.12.2011, 16:34:30    Sujet du message: Répondre en citant
Sur l'EB4S3, les amortos sont à clapet (avec des billes), difficile à règler et mauvaise tenue de l'huile (beaucoup de cisaillement).
Le système est peut être mieux conçu Question
Quelqu'un connait?
