RCmag :: Voir le sujet - Micro Interrupteur Xpert
philippe27
MessagePosté le: 24.02.2017, 19:49:31    Sujet du message: Micro Interrupteur Xpert Répondre en citant
Xpert electronic power switch as used by many top drivers to give a more reliable switch than a standard mechanical unit.
This is fully compatible with all common types of reciever battery pack. Using two LED's the switch provides feedback regardin its current status and battery voltage.
L1 Light indicates battery type selected. Solid light indicates high Voltage (LiPO LiION) and flashing indicates low voltage (NiMH and LiFE).
L2 provides feedback about battery voltage and will flash when the voltage drops to a pre determined level of 5.3V NiMH/6.8V LiPo and will become solid at 4.8V NiMH/6.4V LiPo indicating the battery is below useable levels.
The switch does not replace a failsafe setting on your radio and simply provides feedback on battery status.
Be aware that as with all electronic switches the switch will draw some power when left turned off so for periods of starage between races we reccomend that the switch be disconected from the reciever battery pack.
Specification:
Input Voltage: 6.0V - 7.4V
Output Voltage: DC 6V/10A - 7.4V/8A
Battery Mode: NiMH/LiPo
Dimensions (LxWxH): 29.4x19x11.3mm
Mounting Dimensions: 28.5x16mm Includes bracket with holes for transponder mounting location.
Weight: 10g
YaYa
MessagePosté le: 25.02.2017, 11:14:44    Sujet du message: Répondre en citant
Quelqu'un peut m'expliquer comment un interrupteur électronique sur OFF peux drainer de la batterie ? Surprised Mad
Fram
MessagePosté le: 25.02.2017, 12:12:37    Sujet du message: Répondre en citant
A partir du moment ou tu as de l’électronique actif, il y a forcement des composants qui consomment.
Meme si c'est qques µA, ca consomme, donc attention aux périodes de stockage longues qui peuvent flinguer les accus.
YaYa
MessagePosté le: 25.02.2017, 12:25:00    Sujet du message: Répondre en citant
Bah c'est pas actif puisque c'est éteint Mad
Donc 2 servos et un transpondeur branchés aux fesses d'un interrupteur électronique éteint consomment encore plus ?
J'ai du mal à comprendre... un interrupteur à 2 états : allumé et éteint, où est le truc ?
Question Mad
freddy31
MessagePosté le: 25.02.2017, 12:33:31    Sujet du message: Répondre en citant
Comme il surveille la tension basse lipo/nimh, même éteint il continu de surveiller la tension.
Donc ça pompe du jus et il est conseillé de débrancher celui-ci si vous ne roulez pas OK!
Aller le stade !!!
Fram
MessagePosté le: 25.02.2017, 12:35:51    Sujet du message: Répondre en citant
Fais la distinction entre la fonction inter. et les composants qui supervisent cette fonction:
il n'y a pas de conso. de tes servos et récepteur qd l'inter est off, on est d'accord.
Par contre, tu as des composants électroniques actifs qui consomment que ton inter soit off ou on. Il faut les alimenter dans tous les cas.
YaYa
MessagePosté le: 25.02.2017, 12:58:03    Sujet du message: Répondre en citant
Ok compris Mr. Green
MessagePosté le: 25.02.2017, 19:02:16    Sujet du message: Répondre en citant
ce qui voudrait dire que l'inter n'isole pas directement de l'accu , mais isole seulement une partie de l'electronique ( sans doute le circuit des servos et la puce )
parce que si on coupe une polarité de l'accu, c'est a dire que l'on interromp le passage du courant vers un circuit consommateur....je vois pas comment l'accu pourrait se vider ( mis a part son autodecharge eventuelle )
ce n'est donc pas des inters a proprement parler Idea Idea Laughing
YaYa
MessagePosté le: 25.02.2017, 19:29:19    Sujet du message: Répondre en citant
d'où ma perplexité Miniman OK!
les fabricants nous spolient !!! Laughing
MessagePosté le: 25.02.2017, 19:55:26    Sujet du message: Répondre en citant
en plus vu le cablage de certains interupteurs , on multiplie par 3 ou 4 la possibilité de faux contacts
....mais visiblement cela doit bien fonctionner vu le nombre important utilisés sur nos bolides (....ou un effet de mode Idea Idea ) Question
YaYa
MessagePosté le: 25.02.2017, 20:08:32    Sujet du message: Répondre en citant
Moi personnellement j'en utilise un car :
1) je suis un geek en puissance et que l’électronique c'est top Mr. Green
2) j'ai un indicateur visuel qui me dit si je suis en nimh ou en lipo, si en lipo, l'état approximatif de la batterie
3) le lipo cutoff réglé par défaut et non modifiable sur 3.2V par cellule soit 6.4V en 2S
4) c'est beau Mr. Green
Arrow
EDIT : j'utilise ce modèle, copie d'une copie d'une copie d'une copie... bref, tout le monde fait le même, il doit y avoir un seul fabricant et tout le monde rebadge...
https://www.wartelle-shop.com/boutique/fiche_produit.cfm?ref=ANSPOWS01&type=713&code_lg=lg_fr&num=45
Bruns
MessagePosté le: 25.02.2017, 20:47:58    Sujet du message: Répondre en citant
Houla !!! Mais il n'y a plus qu'un pas pour que tu passes au Brushless mon YaYa !!! Laughing
T'es déjà à moitié converti Razz
Serpent SRX8 - RC Concept - OS / SRX8e - Hobbywing
YaYa
MessagePosté le: 25.02.2017, 20:54:43    Sujet du message: Répondre en citant
Comptes y bien Bruno Laughing j'aime pas le délire du brush, j'ai l'impression vraiment que c'est du jouet à pile Arrow
mugray
MessagePosté le: 26.02.2017, 09:18:05    Sujet du message: Répondre en citant
moi le mien m'a fait la saison(5cf,5 ligues et quelques roulages)
mais a montré des signes de faiblesse a la fin mais seulement pour l'allumer ou l'éteindre mais une fois en marche pas de soucis!
il était fixé sur la boite radio avec un double face moussé et vissé(pas trop sérré) pour sécuriser tout ca!
quand on a pas de mécano atittré je trouve ca mieux que de tirer sur les fils des connectiques pas toujours trés fiable a force de tirer!mais pour plus de sécurité il vaut mieux en changer une fois en milieu de saison je pense!
HB D817 6MIK TRACKISOPEN
YaYa
MessagePosté le: 26.02.2017, 09:20:21    Sujet du message: Répondre en citant
Mon inter a fait 2 saisons complète et il ne montre pas de signes de faiblesses OK!
philippe27
MessagePosté le: 26.02.2017, 12:23:53    Sujet du message: Répondre en citant
vous avez vu la version tactile
https://www.rcmag.com/modules.php?name=Forums&file=viewtopic&p=932607#932607
Enrok
MessagePosté le: 27.02.2017, 11:04:38    Sujet du message: Répondre en citant
J'ai un interrupteur de ce type qui m'a fait toute la saison impeccablement et hier en cours d'entraînement l'alimentation électrique du récepteur et des servos a coupé, je me suis retrouvé avec une voiture incontrôlable qui bien évidemment est parti dans le décor, résultat un triangle de casser.
Est-ce un phénomène que vous avez déjà rencontré chez vous? Le mien est un SkyRC.
MessagePosté le: 27.02.2017, 13:24:31    Sujet du message: Répondre en citant
c'est le risque comme avec n'importe quelle connexion....le risque zero n'existe pas ...
ces interrupteurs sont a la longue sensibles au vibrations et certains subissent un decollement des soudures
mais aussi vous avez 3 ou 4 fois plus de risques de mauvais contact tant les connections sont multipliées , d'ou des risques de pertes de controles
je reconnais le coté pratique , on passe le doigt sous la carro et on appui, c'est plus pratique que de brancher un connecteur
maintenant avec l'utilisation quasi generalisée du 2.4GHZ ,il est aussi simple de brancher direct via une prise futaba, dean,tamiya...ou autre 5mn avant le depart de la manche dans les stand
ce n'est que mon avis
freddy31
MessagePosté le: 27.02.2017, 13:31:29    Sujet du message: Répondre en citant
Cela m'est arrivé aussi et ça fait bizarre surtout quand tu est plein gaz ...
Du coup j'ai refais ma connectique avec des connecteurs xt30 et fils de plus gros diamètre OK!
Aller le stade !!!
Fram
MessagePosté le: 27.02.2017, 13:49:47    Sujet du message: Répondre en citant
Ouvrez le boitier, verifiez les soudures et reprenez les le cas echeant.
Ensuite surmoulage de l’électronique a la résine epoxy (type araldite), vous verrez, ca ne bronchera pas dans le temps. OK!
