Posté le: 10.08.2017, 14:49:36 Sujet du message: Buggy 4x2 22 4.0 SR Spec Racer TLR
In true TLR fashion, handling was a particular focus. A laydown transmission moves the motor forward by 20mm+ to a central motor location and provides two diff heights-standard 3.0mm and +3.5mm for carpet and Astroturf. This creates a chassis that drives much flatter, more consistent and corners quicker, especially on throttle which is critical for spec racing.
All told, the 22 4.0 SPEC-Racer weighs in under the ROAR minimum weight of 1499g, with no modification. But it's the moment you hit the track when the advantages becomes clear. Front to back, the 22 4.0 SPEC-Racer is more capable of competing for wins right out of the box than any other stock 1/10 2WD buggy in its class.
Disponible mi septembre.
Source TeamLosiRacing _________________ Papy boomer
Elle est pas belle la vie?
Tous les logos et les marques présents sur ce site appartiennent à leur propriétaires respectifs Les commentaires et le contenu quand à eux sont sous la responsabilité de ceux qui les écrivent.
Copyright 2006-2024 RCmag.com page générée en 0.03 S
