RCmag :: Voir le sujet - A-t-on déjà parlé de ce RC Elect Basher BSR 1/8 Scale 4WD Ra
philippe27
MessagePosté le: 01.11.2015, 18:46:34    Sujet du message: A-t-on déjà parlé de ce RC Elect Basher BSR 1/8 Scale 4WD Ra Répondre en citant
Bonsoir
A-t-on déjà parlé de ce RC Elect Basher BSR 1/8 Scale 4WD Rally Car
(Ready-To-Run) (UK Warehouse)
Votre avis sur ce Rally Car 1/8
New from Basher, the ready-to run BSR 1/8 Scale Rally car!
Built on a rugged buggy platform with refinements to handle the rigors of on AND off road driving, the BSR Rally is a beast of a vehicle!
The BSR Rally 1/8 Scale rally car features a monster 4-cell capable brushless power system and puts all that power down through an all steel 4WD drive transmission. With big bore alloy shocks and heavy duty components, this car can launch off almost anything and just keep on goin'. The chassis features all the same adjustability you would expect from a full race vehicle including camber, toe, and shock position so you can tune your BSR Rally for every surface condition.
The attention to detail on this car is extraordinary. The engineers and designers at Basher underwent an extensive testing and development process to ensure no shortcuts were taken. Team Basher understands the importance of after sales support and offer a full range of spares for your battle scarred car along with an awesome range of hop-up parts to upgrade your ride.
Features:
• Powered by two 7.4V 2S Lipoly battery
• 4 wheel drive with front/mid/rear steel diff.
• Adjustable Toe, Camber and shock position
• Pre-glued DMACK On-road Rally Tires
• 3mm Aluminum chassis
• Powerful 2100KV brushless motor with a stable 120A ESC support.
• Tie rod and camber link are made by steel, increase the reliability.
• 17mm Aluminium Big Bore Shock
Specs:
Width: 305mm
Height: 200mm
Length: 530mm
Wheelbase: 327mm
Ground clearance: 17mm
Motor: 2100KV, 40mm Brushless
ESC: 120A waterproof
Servo: Water resistant metal gear
Drive: Shaft Drive full time 4WD
Battery compartment: 137mm x 47mm (7.4V Lipoly Hardcase Battery)
Required:
2 x 30C 2S 7.4V 5000mAh Hardcase Lipoly Batteries
4 x AAA Batteries (For Transmitter)
PRODUCT ID: 9424000001
http://www.hobbyking.com/hobbyking/store/__65386__Basher_BSR_1_8_Scale_4WD_Rally_Car_Ready_To_Run_UK_Warehouse_.htmlBasher BSR 1/8 Scale 4WD Rally Car (Ready-To-Run) (UK Warehouse)
philippe27
MessagePosté le: 01.11.2015, 18:47:44    Sujet du message: Répondre en citant
[url][/url]
[url][/url]
philippe27
MessagePosté le: 01.11.2015, 18:48:23    Sujet du message: Répondre en citant
[url][/url]
Phred
MessagePosté le: 01.11.2015, 21:53:51    Sujet du message: Répondre en citant
Pas mal de pièces identiques au TeamC (ou Stoke, Absima, ...), ça doit sortir du même moule...
(et le moteur est le Turnigy que j'utilise depuis des centaines de packs : increvable)
philippe27
MessagePosté le: 02.11.2015, 23:33:19    Sujet du message: Répondre en citant
effectivement il y a de la ressemblance
http://www.teamcracing.net/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=717&category_id=70&option=com_virtuemart&Itemid=71
http://www.teamcracing.net/components/com_virtuemart/shop_image/product/GT8_1_8_Nitro_GT_4f584ec68edc9.jpg
http://www.teamcracing.net/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=705&category_id=70&option=com_virtuemart&Itemid=71
http://www.teamcracing.net/index.php?page=shop.product_details&product_id=1050&flypage=flypage.tpl&pop=0&option=com_virtuemart&Itemid=71
http://www.teamcracing.net/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=846&category_id=68&option=com_virtuemart&Itemid=71
http://www.teamcracing.net/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=706&category_id=68&option=com_virtuemart&Itemid=71
philippe27
MessagePosté le: 03.11.2015, 07:51:07    Sujet du message: Répondre en citant
on les voit en rallye game ces modèles ????
