RCmag :: Voir le sujet - Murnan Modified M12
Murnan Modified M12
philippe27
MessagePosté le: 30.12.2015, 13:48:30    Sujet du message: Murnan Modified M12 Répondre en citant
The Murnan Modified M12 is a pure bred racing engine. The M12 engine parts are made of the finest components available in the world. The parts are then modified, and assembled by Murnan. Not only is this our most powerful .12 engine to date, it is also durable, and easy to tune.
The M12 engine makes an extreme amount of torque throughout the entire powerband. This makes the car seemingly explode from corner to corner, while still pulling hard to a high top speed. The engine will also easily finish 5 minutes with fuel to spare.
Displacement: 2,1 cc
R.P.M. (max power): 39,500 RPM
Practical RPM range: 6,000 - 45,000
Bore x stroke: 13,70x14,25 mm
Sleeve: 3 ports
Piston: CNC
Rear ball bearings: Steel
Front ball bearings: Steel
Crankshaft: 11.5 mm – Turbo-Balanced
Carburetor: aluminium - 6,5 mm - slide
Glowplug: Turbo (C6TGF)
Exhaust position: rear
Weight: 220 g
Fuel Tupe: 16-25% nitro
Suggested Exhaust:
Novarossi 2660
Hipex 2669
http://www.murnanmodified.com/index.php?route=product/product&product_id=1199
http://www.murnanmodified.com/index.php?route=product/category&path=136_43_67
http://www.murnanmodified.com/index.php?route=product/category&path=136_43_70
http://www.murnanmodified.com/index.php?route=product/category&path=136_21_72
http://www.murnanmodified.com/index.php?route=product/category&path=136_21_73
http://www.murnanmodified.com/index.php?route=product/category&path=136_142
