RCmag :: Voir le sujet - Control LEDs from your transmitter. Futaba
philippe27
MessagePosté le: 01.03.2017, 20:26:20    Sujet du message: Control LEDs from your transmitter. Futaba Répondre en citant
CPS-1
Channel Power Switch
SEARCH:
CPS-1 (See larger view)
Easy to install — simply plug into a receiver channel.
Turn lights installed on your model on and off at any time.
Very compact and lightweight.
Great for airplane and heli orientation and night flying, or operating light bars, running lights or chassis under-lighting on cars and trucks.
For use with radios with 3 or more channels with switches.
$44.99
Qty for FUTM0940:
Tech Notes
Stock Number
FUTM0940
Main Application
control of LEDs via your transmitter
Current Drain
10mA @ 6.0V
Output Voltage
depends on the receiver power supply
Output Current
200mA or less
Operating Temperature Range
-10 to +45°
Power Requirement
NiCd, NiMH 4-5 cells equivalent battery
Dimensions
0.63 x 0.87 x 0.30 in (16 x 22 x 7.6 mm)
Weight
0.21 oz (5.9 g)
http://www.futabarc.com/accessories/futm0940.html
http://www.gpdealera.com/cgi-bin/wgainf100p.pgm?I=FUTM0940
