RCmag :: Voir le sujet - Découverte de la Capricorn C803 de Robin D’Hondt °
MessagePosté le: 27.09.2017, 17:58:47    Sujet du message: Découverte de la Capricorn C803 de Robin D’Hondt ° Répondre en citant
Sur red rc
http://www.redrc.net/
Chassis – Capricorn C803
Engine – Tesla T21
Tyres – Matrix (Handout)
Fuel – Energy
Radio/Servos – Sanwa
Body – Protoform R19
Remarks – Capricorn factory driver Robin D’Hondt is running a C803 from the Italian factory equipped with an Evo chassis. The Belgian is also using a pair of separate gearbox shaft mounts in order to increase the flex of the rear end, a 6mm lightweight transmission axle, front and rear cvd’s with aluminium wheel axles and a new bumper, which is stiffer and holds the body posts directly.
MessagePosté le: 27.09.2017, 17:59:22    Sujet du message: Répondre en citant
MessagePosté le: 27.09.2017, 18:00:00    Sujet du message: Répondre en citant
MessagePosté le: 27.09.2017, 18:00:28    Sujet du message: Répondre en citant
