RCmag :: Voir le sujet - Nouveaux servo Team Tekin.
MessagePosté le: 06.12.2017, 14:47:57    Sujet du message: Nouveaux servo Team Tekin. Répondre en citant
T-120 Lo-Pro Speed with aluminum Vector 20mm arm
T-180 Lo-Pro Torque with aluminum Vector 20mm arm
T-130 Speed with aluminum Vector 20mm arm
T-190 Torque with aluminum Vector 20mm arm
T-250 Speed with aluminum Crowbar clamping-type 20mm arm
T-300 Torque with aluminum Vector 20mm arm
T-360 Torque with aluminum Crowbar clamping-type 20mm arm
T-440 Torque with aluminum Crowbar clamping-type 20mm arm
​ – Specifically Designed for 1/10 and 1/8 Scale Applications
​ – Included Aluminum 20mm Crowbar HD Clamp Servo Arm
​ – Full Aluminum Servo Housing
​ – Element Proof Design
​ – Precision Cut Full Metal Gears
​ – ABEC5 Ball Bearings
​ – Digital Magnetic Position Encoder
​ – High Voltage Capable
​ – High Torque Coreless Motor
​ – 25T Output Spline
​ – Overload Protection Technology
​ – Thermal Protection Circuitry
​ – Low Voltage Alarm**
​ – Quiet, Efficient, Cool Operation
​ – HDAC: High Density Copper PCB’s
HOTWIRE™ programmable features:
​ – Feel – Mild to Aggressive
​ – Speed Limit
​ – Torque (0-100%)
​ – Torque Delay
​ – Direction – Normal / Reverse
​ – Center Point
​ – Travel
​ – Soft Starting Speed & Torque
​ – Max Temp Alarm
​ – Over Voltage Alarm
​ – Bind Relief
​ – Fail Safe Speed and Position
​ – Set Custom Servo Name
Toutes les caractéristiques servo sur TeamTekinServo
Papy boomer
Elle est pas belle la vie.
MessagePosté le: 06.12.2017, 15:25:49    Sujet du message: Répondre en citant
Une marque historique de la RC OK!
