Posté le: 07.03.2018, 10:33:07 Sujet du message: Kit de conversion "dirt" XRAY pour XB2
#323325 Alu Rear Longer Lower Susp. Holder – Narrow – Rear (10mm)
#325002 Ball Adjust. Diff for 2.5mm Pin – Set – HUDY Spring Steel™
#325323 Rear Drive Shaft 71mm with 2.5mm Pin – HUDY Spring Steel™
#327310 Rear Suspension Pivot Pin 3×46 mm (2)
#363111-H Composite Suspension Arm Rear Lower Right – Hard
#363121-H Composite Suspension Arm Rear Lower Left – Hard
Source TeamXRAY _________________ Papy boomer
Elle est pas belle la vie?
