RCmag :: Voir le sujet - Chargeur Hitec X1 Mini – AC Input Balance Charger/Discharger
philippe27
MessagePosté le: 13.01.2016, 19:49:38    Sujet du message: Chargeur Hitec X1 Mini – AC Input Balance Charger/Discharger Répondre en citant
X1 mini – AC Input Balance Charger/Discharger
Product Description
Hitec’s unbeatable battery charger is the new X1 mini. It is the perfect affordable answer for beginner hobbyists as well as an excellent addition to the experienced RC enthusiasts’ charger collection. Featuring a compact design for maximum portability and convenience, the reliable X1 mini delivers 60 watts of power and capably charges all battery chemistries, including the new generation LiHV. Its 6-amp power supply and user-friendly software will keep you fully charged and ready, both in the workshop and on the go!
Features
Compact Size and Stylish Design
Battery Meter
Battery Internal Resistance Meter
PC Communications: USB Port for PC Control & Firmware Upgrade
Re-Peak Mode for NiMH/NiCd Batteries
Charger Protection: Over Temperature, Over Capacity & Over Short Circuit Reverse Polarity
Specifications
AC Input: 100-240 Volts AC
Total Charge Circuit Power: 60 Watts AC Input
Charge Current Range: 0.1 - 6.0 Amps
Discharge Current Range: 0.1 - 2.0 Amps
Discharge Current Power: 10 Watts
Charges NiMH, NiCd, LiPo, LiHV, LiFe, Li-Ion and Lead Acid Batteries
NiCd/NiMH Cell Count: 6-8 Cells
LiPo/LiHV/Li-Ion/LiFe Cell Count: 2-4 Cells
Pb Voltage: 6-12 Volts
Net Weight: 0.68 lbs (310g)
Dimensions: 4.41 x 4.17 x 2.05in (112 x 106 x 52mm)
http://hitecrcd.com/images/products/pdf/419_X1mini_Manual_BAS-Web.pdf
http://hitecrcd.com/new-products
