RCmag :: Voir le sujet - Chargeur Eachine GEMINI 2100 AC/DC 2*80W Dual Balance Charge
philippe27
MessagePosté le: 30.03.2016, 09:01:06    Sujet du message: Chargeur Eachine GEMINI 2100 AC/DC 2*80W Dual Balance Charge Répondre en citant
Eachine GEMINI 2100 AC/DC 2*80W Dual Balance Charger Discharger 3-6S for NiCd NiMH Lilo LiPo LiFe PB.
Eachine GEMINI 2100 Description:
Brand Name: Eachine
Item Name: Charger
Item NO.: GEMINI 2100
Dual Input Power(AC/DC): AC 100V-240V; DC 11v-18V max.
Circuit Power: 80W for charging max.; 5W for discharging
Charge Current Range: 0.1A-7.0A
Discharge Current Range: 0.1A-1.0A
Current Drain For Balancing LiPo: 300mAh/Cell 1-15 cells
NiCd/NiMH Battery Cell Count: 1-15 Cells
Lithium Battery Cell Count: 1-6 Series
Pb Battery Voltage: 2 to 20V
Weight: 930g
Size: 96x 138 x 192mm
NiCd/NiMH:
Voltage Level: 1.2V/cell
Allowable Fast Charge Current: 1C~2C depends on the performance of cell
Discharge voltage cut off level 0.85V/cell(NiCd),1.0V/cell(NiMH)
Lilo:
Voltage Level: 3.6V/cell
Max. Charge Voltage: 4.1V/cell
Allowable Fast Charge Current: 1C or less
Min. Discharge Voltage Cut off Level: 2.5V/cell or higher
LiPo:
Voltage Level: 3.7V/cell
Max. Charge Voltage: 4.2V/cell
Min. Discharge Voltage Cut off Level: 3V/cell or higher
LiFe:
Voltage Level: 3.3V/cell
Max. Charge Voltage: 3.6V/cell
Allowable Fast Charge Current: 4C or less(eg. A123M1)
Min. Discharge Voltage Cut off Level: 2.0V/cell or higher
PB:
Voltage Level: 2V/cell
Max. Charge Voltage: 2.46V/cell
Allowable Fast Charge Current: 0.4C or less
Min. Discharge Voltage Cut off Level: 1.5V/cell or higher
Eachine GEMINI 2100 Features:
Can be powered by AC100-240V or DC 11-18V.
Dual Charge Circuitry
Two individual charging circuits allow you to charge 2 batteries simultaneously, regardless of battery chemistry or cells
High Power Charging Circuit
A powerful 80-Watt charging circuit. The charger can safely charge or discharge up to 15 cells of NiMH or NiCd batteries and up to 6S LiPo batteries.
Lithium Cell Voltage Monitoring
Can monitor and balance LiPo cells in either charge or discharge mode.
Multiple Chemistgry Charging
Will charge NiMH, NiCd,Lilo,LiPo,LiFe and Pb battery types.
Eachine GEMINI 2100 Package:
1 x Charger
1 x Alligator Clips
1 x Deans Plug
2 x Blance Block
2 x Blance Cable
1 x Charging Cable
MessagePosté le: 30.03.2016, 10:51:53    Sujet du message: Répondre en citant
J'aime
