RCmag :: Voir le sujet - Triangles durs HB 815/RGT8
speedy2
MessagePosté le: 19.09.2016, 10:12:57    Sujet du message: Triangles durs HB 815/RGT8 Répondre en citant
#115833 FRONT SUSPENSION ARM SET (HARD)
These front suspension arms are made from harder material for increased arm stiffness.
These are standard equipment on the RGT8, and after testing with our factory off-road drivers, they concluded that when installed on the D815
the harder material improves handling on high traction surfaces and reduces the sensitivity of the car to variations in traction.
Compatible with: D815 V2, D815, D812, RGT8, E817
EAN: 4944258039565
#115835 REAR SUSPENSION ARM SET (HARD)
These rear suspension arms are made from harder material for increased arm stiffness.
EAN: 4944258039572
