RCmag :: Voir le sujet - Runcam Swift Mini FPV Camera Overview
philippe27
MessagePosté le: 20.02.2017, 19:45:03    Sujet du message: Runcam Swift Mini FPV Camera Overview Répondre en citant
Spec
Dimension 22.3 x 22.0 x 27.0mm (WxHxL).
Weights 12g
Voltage Input: 5 to 36V
600 TVL
Dimension of the Swift Mini is 22.3 x 22.0 x 27.0mm (WxHxL). It weights 12g only. The mounting holes are M2, distance is 6mm to the next one.
Compared to the Swift 2, dimension is 28.5 x 26 x 27mm (WxHxL).
Camera comes with 2 colours, the iconic orage and black.
There are 3 lens options:
FOV 130° 2.5mm
FOV 150° 2.3mm
FOV 165° 2.1mm
PAL/NTSC is not a camera setting, but you can choose your preference when buying.
https://oscarliang.com/runcam-swift-mini-fpv-camera-overview/
