RCmag :: Voir le sujet - Chargeur Hitec H4 Plus DC/DC Four-Port Smart
Auteur
Message
philippe27 Champion du monde Inscrit le: 10/08/2005 Messages: 6910
Posté le: 25.06.2017, 19:12:05 Sujet du message: Chargeur Hitec H4 Plus DC/DC Four-Port Smart
Product Description
Features
Luxury High Performance 4-channel Smart Charger
Full aluminum case
32bit high performance microprocessor controlled
High quality 128x64 Back Light Graphic LCD
High Power 150watt x 4channel
Hitec Channel Bridge Function (Max Charge - 300watt)
Lithium Chemistry Battery (Li-HV, Li-Po, Li-Fe, Li-ion)
NiMH , NiCd, Pb Battery capable
Li-xx Storage Mode (Auto Detecting)
Ni-xx Cycle Charge & Discharge (Up to 10-cycle)
Built in Cell check Function (Voltage level & Capacity)
Lithium Chemistry Battery Discard Function
User name (12 character)
Temp Sensor can be connected.
Firmware can be Upgraded by HPP-22
Specifications
Function: Charger, Discharger, Cycle Charger/Discharger (Ni-XX), Balancer (Li-XX), Battery
Voltage Displays(Li-XX), Warning Signals, Safety Features.
Compatible Batteries: Li-Po, Li-Fe, Li-Ion, Ni-CD, Ni-MH, Pb, Li-HV
Available Number of Cells: 1-6 Li-Po, Li-Fe, Li-Ion / 1-15 Ni-MH, Ni-CD / 1-12 Pb (2~24v), Li-HV (1-6)
Input Voltage: DC 11~18V
Charging Current: 4ch (MAX 8A) x 150watts , (MAX 16A) x 300watts(with Hitec Bridge Function)
Discharging Current: 4ch (Max 2A) x 20watts , (MAX 4A) x 40watts(with Hitec Bridge Function)
Balancer Connector Type: MPX, Thunder Power, Flight Power
Maximum Permissible Current: 65A & 13V
Charging Capacity: 600W
Model Memory: 10 model memory per channel
Size: 205mm x 163mm x 52mm
Weight: 1200g
p://hitecrcd.com/products/chargers/dcdc-chargers/h4-plus-dcdc-four-port-smart-charger/product
