RCmag :: Voir le sujet - Chargeur Dynamite Ultra P2 AC Plus 2-Port AC/DC Multi-Charg
philippe27
MessagePosté le: 12.11.2018, 20:36:23    Sujet du message: Chargeur Dynamite Ultra P2 AC Plus 2-Port AC/DC Multi-Charg Répondre en citant
Passport Ultra P2 AC Plus 2-Port AC/DC Multi-Charger (DYNC3016)
https://www.horizonhobby.com/passport-ultra-p2-ac-plus-2-port-ac-dc-multi-charger-p-dync3016
[img]https://s7d5.scene7.com/is/image/horizonhobby/DYNC3016_a5[/img]
Key Features
Powerful 100W AC/DC Multi-Charger
Two channels charge two different kinds of batteries simultaneously
Charges Lipo, LiHV, LiFe NiMH/NiCd, and Pb batteries
Charges 1-6 cell Lipo/ LiHV/LiFe, 1-15 cell NiMh/NiCd, and 2-20V Pb
Dynamite Dashboard-Smart phone control and monitor via Bluetooth
High visibility, simplified LCD interface
Built-in balancing ports
Integrated voice functionality
5-year limited warranty
Overview
The Dynamite® Passport™ P2 AC Plus 2 Port AC/DC Multi-Charger represents the pinnacle of premium, high-performance chargers. With dual 100W output capability, the Passport P2 can charge Li-Po batteries in half the time it takes lower wattage/amperage chargers. In addition, you get the full gamut of charging features, including the ability to charge virtually all battery types and intuitive LCD display.
https://www.horizonhobby.com/pdf/DYNC3016-Manual-EN.pdf
From Dynamite RC:
Features:
Specs:
Ampere Meter: Yes – on main LCD display
Battery Balance Connector: XH Balancing Adapter Board
Battery Temperature Monitoring: No/Yes – Temperature Sensor (not) included
Battery Type: 1â??2S LiFe, LiIon, LiPo; 1â??2C NiCd, NiMH; 2â??12V Pb
Cooling Method: Cooling fan
DC Output: 100W max AC, 200W DC
Discharge: Yes
Display: Yes
Height: 67mm
Input Connector: AC cord, detachable, North American plug
Input Voltage: 100-240V AC or 11-18V DC
Integrated Balancing: Yes – Internal Balancer & External Adapter
Length: 140mm
Low Input Voltage Protection: Yes
Maximum Charge Rate: 0.1Aâ??10A x 2
Maximum Continuous Discharge Rate: 0.10Aâ??2.0A x 2
Model Memory: No/Yes – #
Output Connector: Banana Plug to EC3
Over Current Protection: Yes
PC Required: No
Peak Detection: Yes
Reverse Polarity Protection: Yes
Safety Timer: Yes
Selectable Charge Rate: Yes – Fixed Rate
Short Circuit Protection: Yes
Thermal Protection: Yes
Voltage Meter: Yes – on main LCD display
Weight: 668g
Width: 153mm
#DYNC3016 – $109.99
Visit DynamiteRC.com
See more posts about Dynamite RC
Dynamite Passport Ultra P2 AC Plus 2-Port AC/DC Multi-Charger Dynamite Passport Ultra P2 AC Plus 2-Port AC/DC Multi-Charger Dynamite Passport Ultra P2 AC Plus 2-Port AC/DC Multi-Charger
