philippe27 Champion du monde
Posté le: 07.02.2010, 14:20:48 Sujet du message: Venom VMX 450 1/4th Scale RTR Dirtbike |
Features:
* Fully adjustable rear wheel gyro system with integrated Beadlox tire system (Patent Pending)
* Beadlox wheels and tires with Griplox style molded inserts front and rear
MTCS - Mechanical Traction Control System (Patent Pending) - Adjustable traction control to adapt to different surface conditions
* Large volume front forks feature dual o-ring seals with Teflon bushings and a pass thru fluid spring perch
* Externally Adjustable Slipper clutch system
* Machined aluminum front forks, triple clamps, steering damper, rear sprocket, rear shock and motor mount
* Direct steering featuring a dampened steering linkage
* 2.4Ghz 3Ch digital programmable radio with 3rd channel mixing and high torque steering servo
* V 540 Series Brushless power system included
* Enclosed Battery compartment accommodates standard 6 & 7cell NiMH stick and 2 & 3 cell LiPO packs
* Integrated water resistant radio box
* Highly detailed pre-printed polycarbonate body work
* True to scale chassis, engine, exhaust, and radiator details
* Molded Neocell foam scale rider figure
* Real steel roller chain
Specifications:
Age Rating: 14+ With Adult Supervision
Scale: 1/4th
Length: 21.57" (548mm)
Width: 11.32" (287.5mm) w/ guide wires
Height: 12.24" (311mm) w/o rider
Wheelbase: 14.56" (370mm)
Ground Clearance: 3.27" (83mm)
Motor: 540 class Brushless Motor
Batteries: 6-7cell Stick Pack NiMH or 2-3cell LiPO Pack
Tech Notes:
You will need 8 AA Alkaline Batteries for the transmitter.
Inscrit le: 14/09/2005 Messages: 26240 Localisation: Orléans
Posté le: 07.02.2010, 14:26:55 Sujet du message: |
_________________ Papy boomer
Posté le: 07.02.2010, 15:01:00 Sujet du message: |
un point de détail intéressant
Posté le: 07.02.2010, 15:11:19 Sujet du message: |
Quel est ce point de détail _________________ Papy boomer
bisou Expert*
Posté le: 07.02.2010, 15:16:51 Sujet du message: |
Papymini a écrit: | Quel est ce point de détail |
un gyro méca peut être _________________ Ile de la Réunion
>> WSY Cyril <<
Email ligue 21 >> ligue21_cyril@hotmail.fr
www.cmdr.re |
Posté le: 07.02.2010, 17:56:22 Sujet du message: |
intéressant de voir le détail de ce planétaire dans la jante
c'est tout pour la curiosité |
Posté le: 07.02.2010, 19:56:30 Sujet du message: |
bisou a écrit: | Papymini a écrit: | Quel est ce point de détail |
un gyro méca peut être |
oui c est 1 gyro mecanique reglable pour la stabilité a basse vitesse avec 1 masse tournante
Posté le: 08.02.2010, 08:06:29 Sujet du message: |
Posté le: 08.02.2010, 14:23:54 Sujet du message: |
le pilote a peindre c est top |
Posté le: 08.02.2010, 14:29:34 Sujet du message: |
Proverbe:
Mieux vaut un pilote à peindre, qu'un pilote qui fait le peintre _________________ Papy boomer
Posté le: 08.02.2010, 15:34:58 Sujet du message: |
ou encore 1 pilote de cross qui se fait repeindre :couleur preferée : mud ou darckmud |
phicaloma Découverte
Posté le: 18.02.2010, 13:14:09 Sujet du message: |
traxxmanfather a écrit: | le pilote a peindre c est top |
Ce serait top, si c'était le cas !
En fait c'est le master, la forme qui va permettre de fabriquer le moule. Le pilote définitif lui sera peint (ce qui n'empêchera pas de le repeindre en mud, darkmud ou lightsand...). |
SebLeLoch Elite
Inscrit le: 01/02/2010 Messages: 1590 Localisation: Nantes
Posté le: 19.12.2010, 14:52:22 Sujet du message: |
Sympa la vidéo, ça à l'air bien fun ! |
Lalain Ligue
Posté le: 22.01.2011, 18:34:06 Sujet du message: |
C'est sans doute la meilleure moto tout-terrain actuellement
MilacH Elite
Inscrit le: 28/09/2009 Messages: 1734 Localisation: Nemours
Posté le: 23.01.2011, 04:55:00 Sujet du message: |
ah ca y est elle est en vente pour de vraie ? .... _________________ Ce n'est pas l'arrivée qui compte, mais le chemin.
JQProducts, Picco, Spektrum, Savox, 6mik |
Lalain Ligue
Posté le: 23.01.2011, 06:02:28 Sujet du message: |
OUI !! |
Lalain Ligue
