RCmag :: Voir le sujet - Gamme Chargeurs I Max Rc 2012
RCmag Index du Forum » Les batteries et chargeurs
philippe27
MessagePosté le: 11.02.2012, 12:05:16    Sujet du message: Gamme Chargeurs I Max Rc 2012 Répondre en citant
Imax B610 Twins pro
http://www.imaxrc.com/B610-Twins.html
SPECIFICATIONS
* Operation voltage range : DC: 11.0~18.0 Volt
* Circuit power: Max : Charge power 2*200Watts
* Max :Discharge power 2*25
* Charge current range : (0.1~10A)
* Discharge current range : 2*(0.1~5A)
* Current drain for balancing Li-Po/Lon/Fe : 200Ma/cell
* Li-ion/Fe/Polymer cell count : (1~6cells)
* NiCd/NiMH battery cell count : 1~18cells
* Pb battery voltage : 2V~24V
* Net weight : 350g
* Dimension : 160*200*60mm
Imax RC 4B6 06 Pro Intelligent Balance Charger
XRC Charger Names
Item Number: 471032
IMAX RC 4B6 06 PRO INCLUDES
Input voltage: 11-18VDC
Charge power: 80Wx4
Power Source: 12V DC(car battery)/AC mains PSU(>200watts)
Cell count: 1-18 NiCd/NiMHx4/ 1-6 Li-ion/Polymer Cellx4/ 1-10 Lead acid cells(2~20V)x4
Current drain for balancing Li-ion/Polymer cell: 20mAh/cell
Charge termination NiCd/NiMH: Automatic, negative Delta Peak method
Charge termination Lead acid&Li-ion/Polymer: Automatic, negative dependent, CC-CV process
Dimension: 220mm X 150mm X 40mm
Weight: 1300g
http://www.imaxrc.com/4B606-Pro.html
max RC 4B6 Pro Intelligent Balance Charger
IMAX RC 4B6 PRO RC PECIFICATION
* Input voltage: 11-18VDC
* Charge power: 50Wx4, current is regulated accordingly
11.1Vbattery, charge current appro. 4.5A
22.2V battery, charge current approx.2.2A
* Discharge power: 5Wx4, current is regulated accordingly
* Power Source: 12V DC(car battery)/AC mains PSU(>200watts)
* Cell count: 1-15 NiCd/NiMHx4/1-6 Li-ion/Polymer
Cellx4/1-10 Lead acid cells(2~20V)x4
* Current drain for balancing Li-ion/Polymer vell: 300mAh/cell
* Charge termination NiCd/NiMH: Automatic,negative Delta Peak method
* Charge termination Lead acid&Li-ion/Polymer: Automatic,negative dependent, CC-CV process
* Dimension: 230mm X 150mm X 40mm
* Weight: 840g
*The Naming Motivation of IMAXRC Charger Names
IMAX RC 4B6 OMPARISON WITH OTHER CHARGERS:
Batt. Type Lipo LiFe Li-lon NiMH/NiCd Pb
Voltage 3.7V/cell 3.3V/cell 3.6V/cell 1.2V/cell 2.0V/cell
Max. 4.2V/cell 3.6V/cell 4.1V/cell 2.46V/cell
Current <=1C <=4C <=1C 1C~2C <=0.4C
Discharge 3.0V/cell 2.0V/cell 3.0V/cell 1.0V/cell|0.85V/cell 1.75V/cell
IMAX RC 4B6 PRO INCLUDES
* 1. Imax RC 4B6 PRO Intelligent Balance Charger Balance Charger;
* 2. Manual Book;
* 3. 7 Kinds of wires(Tamiya charging cable ,FutabaRX charging cable, JR charging cable, Glow charging cable, Dean charging cable(total4pcs:1pc long,3pcs short),Crocodile clip charging cable, JST/BEC charging cable);
* 4. 4 Kinds of Balance Adapter ( PQ-02 adapter, JST XH adpter, EH-02 adapter, TP/FP-02 adapter);
* 5. 1 pair scissors clip.
http://www.imaxrc.com/4B6-PRO.html
Imax RC B606 AC Pro
http://www.imaxrc.com/B606-AC-PRO.html
Imax B606 AC SPECIFICATION
* Input voltage: 11-18V DC 100-240V AC
* Charge power: max. 80W
* Discharge power: max. 10W
* Charge current range: 0.1-6.0A
* Discharge current range: 0.1-1.2A
* Current drain for balancing LiPo: 300mAh/cell
* Balance tolerance: 0.01V
* NiCd/NiMH battery cell count: 1-18 cells
* LiPo/LiIo/LiFe battery cell count: 1-6 series
* Pb battery voltage: 2V-24V
* Temperature sensor port: YES
* Dimension: 147mm X 145mm X 56mm
* Weight: 980g
IMAX RC B8AC Pro
http://www.imaxrc.com/B8AC-PRO.html
Imax RC B8AC PRO SPECIFICATION
* Operating voltage range: 11-18VDC
12V PSU AC 100~240V (50/60Hz)
* Circuit power: Max. 120W at AC input charge
Max. 180W at DC input Discharge
Max. 25W at AC/DC
* Charge current:0.1 ~ 10.0A
* Discharge current:0.1 ~ 5.0A
* NiCd/NiMH battery cell count:1~ 22cells
* Lithium battery cell count:1~8series
* Pb battery voltage:2~28V
* Battery data memory:10 memories per program
* Battery capacity range:100~65000mAh
* Delta-peak sensitivity:Disable/Delicate/5~200mV adjustable
* Temperature cut-off range: 20~80C/68~176F
* Trickle charge current:Off, 50~300mA adjustable (N/A for Lixx)
* Cycle count: 1~10 times (N/A for Lixx)
* Cycle cool-off wasted time: 0~60 minutes adjustable
* Current drain for balancing Lixx: 200mAh/cell
* Dimension: 260*215*75mm
* Weight: 1420 g
Imax RC B6 TWINS
max RC B6 TWINS High performance and professional Intelligent Digital Balance Charger.
SPECIFICATION
* Operating voltage range: DC: 11.0~18.0V 50/60 Hz
* Circuit power: (Max. charge power 50W)*2
(Max. discharge power 5W)*2
* Charger current range: (0.1A~5.0A)*2
* Discharger current range: (0.1A~1.0A)*2
* Current drain for balancing Li-Po: 300mAh/cell
* Li-Ion/Polymer cell count: (1~6 series)*2
* Pb Battery voltage: (2V~20V)*2
* Dimension: 134*160*32mm
* Weight: 483g(Net Weight)
Autres
http://www.imaxrc.com/B610-PRO.html
http://www.imaxrc.com/B606-PRO.html
http://www.imaxrc.com/B8-PRO.html
http://www.imaxrc.com/B6AC-PRO.html
http://www.imaxrc.com/B6-PRO.html
http://www.imaxrc.com/B4-Compact.html
http://www.imaxrc.com/B3-Compact.html
http://www.imaxrc.com/A3-Compact.html
http://www.imaxrc.com/Maunals.aspx
Alim
http://www.imaxrc.com/B20.html
http://www.imaxrc.com/B35.html
http://www.imaxrc.com/B60.html
catalogue generale
http://www.imaxrc.com/uploads/software/20110801054936367.pdf
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » Les batteries et chargeurs Toutes les heures sont au format GMT + 1 Heure
