philippe27 Champion du monde
Posté le: 19.04.2018, 21:17:25 Sujet du message: Un chargeur qui tient dans la main B6 nano Skyrc |
https://www.skyrc.com/Charger/B6nano
Coming soon from SkyRC is the B6 Nano 320W DC micro multi-chemistry charger. It measures a compact 76x85x37mm and weighs in at only 130g but packs a bunch of features such as a 50×37.5mm black screen display, touch buttons, up to 15A charging current, and 6S LiPo-compatibility. A LiHV mode allows to use the device with the latest generation of high-voltage LiPo batteries and thanks to Bluetooth connectivity the charger can controlled, monitored and upgraded using iOS or Android mobile device apps.
Specifications:
– Input voltage: DC9-32V
– Max charge power: 320W
– Max discharge power: 5W
– Charge current range: 0.1-15.0A
– Discharge current range: 0.1-3.0A
– LiPo/LiFe/Lilon/LiHV cells: 1-6S
– NiMH/NiCd: 1-5 cells
– Pb battery Voltage: 2-20V
– Net weight: 130g
– Dimension: 76x85x37mm |
Posté le: 19.04.2018, 21:18:27 Sujet du message: |
Posté le: 20.04.2018, 11:42:41 Sujet du message: |
francky340 Elite
Posté le: 20.04.2018, 21:02:18 Sujet du message: |
sympathique mais perd un peu de son intérêt comme il doit être alimenté par une alimentation externe _________________ Team CrazyDoc / merci FPmodelisme
Grostony38 Découverte
Posté le: 22.02.2019, 12:54:22 Sujet du message: Skyrc smart nano b6 |
[bonjour je roule en thermique et je voudrais avoir des avis sur le charfeur skyrc smart nano b6[/u] |
rc94.com Présidents Elite
Cubitus Expert**
