RCmag :: Voir le sujet - Le MP9 d'Elliott Boots ( 10/16 )
MessagePosté le: 12.10.2016, 17:18:33    Sujet du message: Le MP9 d'Elliott Boots ( 10/16 ) Répondre en citant
Par http://events.redrc.net
Chassis – Kyosho Inferno MP9 TKI4
Engine – Reds R7 Worlds Edition
Tyres – Pro-Line Holeshot M4
Fuel – Byron Fuels
Radio/Servos – Sanwa
Body – TKI4 High downforce
Remarks – Reigning European Champion and Q1 pace setter Elliott Boots is running the TKI4 version of the Inferno MP9, powered by his new Reds Racing R7 Worlds Edition engine. Using a modified setup he tried at the Worlds warmup they have since made the car softer all round with softer shock and diff oils, having also tried different roll centres but reverted back. Up front Boots tried a new front upper suspension mount with higher roll centres but found he liked the feel of the standard part better. In terms of tires he has tried both ElectroShot and Holeshots but settled on the latter in M4 compound as the traction is quite low.
MessagePosté le: 12.10.2016, 17:19:12    Sujet du message: Répondre en citant
MessagePosté le: 12.10.2016, 17:19:56    Sujet du message: Répondre en citant
MessagePosté le: 12.10.2016, 17:20:39    Sujet du message: Répondre en citant
