RCmag :: Voir le sujet - SWORKz S35-GT 1/8 Nitro GT Kit
RCmag Index du Forum » TT 1/8 Rally Game
philippe27
MessagePosté le: 12.11.2017, 23:46:08    Sujet du message: SWORKz S35-GT 1/8 Nitro GT Kit Répondre en citant
SWORKz have introduced the new S35-GT 1/8th nitro GT kit. Based on the latest SWORKz S35-GTE platform, it features the front and rear suspension design shared with the S35-GTE. The Ackermann steering system came directly from the 1/8th S35-3 nitro Buggy. A new center 2 speed on-road transmission system gives perfect acceleration to the S35-GT. The S35-GT newly designed arms are made from a strong nylon material. Optional carbon covers are available to adjust the arm’s stiffness for different tracks. The new unique front shock tower design allows to change the front upper angle position easily. The T-7075 aluminum chassis with its new design L.F.C (Lower Friction Coefficient) system will give more grip and at the same time less friction for the rear. A new radio tray system provides better and more precise throttle and braking response. The S35-GT includes high quality parts, an refined shock system, more options and an optimized suspension geometry.
S35-GT Kit Features:
S35-GT series Nitro on-road GT Car T-7075 Aluminum Lightened Main Chassis with L.F.C system (Lower Friction Coefficient)
S35-GT Series Front and Rear Pro Shock Towers made of Lightened T-7075 Aluminum for GT-BBS shocks system
S35 Series BBS Emulsion Shock Caps
S35-3 Series Lightened Transmission Gear Box System with High Performance Crown Gears and Pinion Gears
Front and Rear Universal Drive Shafts with Special Lightened 6mm Axle Wheel Hub system
S35-3 Series Aluminum Rear Lower Fully Adjustable Toe-In Block (A)
S35-3 Series Competition Aluminum Steering Knuckle Plates
S35-GT new center 2 speed on-road transmission system.
S35-GT/GTE On Road Bumper and rear body poster system
Heavy Duty Front and Rear Arms
Professional 2.0 Metal Brake Calippers
New 150cc Floating Fuel Filter System Tank
Adjustable Front Upper and Lower Suspension Arm System
S35-3 Series Pro-composite Carbon Front Upper Arm Covers
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » TT 1/8 Rally Game Toutes les heures sont au format GMT + 1 Heure
